FAQ & DIY Frequently Asked Questions & Do It Yourself- Sedan and Coupe. Updates Approved by Administrators and Moderators.
key program - the alternative to the Infiniti ignition key.
Old 03-24-2006, 01:34 AM
Bryant's Avatar
As you all know, I recently puchased my G35 and it only came with one key - the original Infiniti key. After inquiring with my local Infiniti dealership, they informed me they would only program an Infiniti key which they would sell to me for $125 and then program it for $45. I asked if they would program an aftermarket key, namely an Ilco key and they declined, stating they will only touch it if it has the Infiniti logo. This inspired me to figure out a way around the attempted monopoly.
I found an Ilco (iLco) key on ebay for $20.00 including shipping. I have been informed that iLco actually sells Infiniti the key they use. The model number for our G35 key from them is NI04T. Next, I researched the ilco website for the process to program the key and learned that it requires an SDD programming tool. [FN1] [FN2] [FN3] Next, I interviewed local locksmiths and found one with the SDD Programming tool and experience with Infiniti transponders. I made an appointment with him and he cut my iLco key, hooked the SDD programming tool to my car, acquired the four digit pin number, and re-programmed both of my keys. (it is necessary to have all keys when programming a new one). He charged me $65 to cut my iLco key and program it. It works perfectly, as does my original.
The bottom line is that you can avoid the costly dealerhip charges for the creation of an ignition key. This applies to all 2003 - 2005 G35's and am unsure what it takes for the 2006 key or if it is different. I was able to save over $85 and now have a functional key I can use as a backup or main key.
As for the remote control keyless entry FOB, I acquired one of these from ebay for $24 including shipping and programmed it myself, which was very easy. [FN4]
FN1:
http://www.kaba-ilco.com/key_systems...ank_Reference_[2852-E-1105].pdf
FN2: http://www.kaba-ilco.com/key_systems...chines/sdd.asp
SDD
FN3: Also can be programmed by dealership using Original Diagnostic Equipment
FN4: http://www.infinitihelp.com/Ownershi...am_key_fob.htm
Old 03-24-2006, 11:33 AM
Zat_Zuma's Avatar
Nicely done ..... thank you
Old 06-12-2006, 04:25 PM
Jeff92se's Avatar
Red Card Crew
Edit/update:
I too purchased an Ebay remote. I got an used Nissan/Infiniti one. I programmed both (original/ebay) in about 30 seconds. You have to do all at once as the programming requires you to clear the remote code 1st, then recode the remote(s).
I didn't purchase a iLco key but a different one. A Howard key. I came very fast (also from Ebay). My dealer said they would cut/program a non-Infiniti key for $65. But I'm in process of finding a locksmith that can do this as I type here. The key was about $20 also. But I went on Howard's website and they sell them for $10+ shipping.
Old 06-12-2006, 04:48 PM
Msedanman's Avatar
O.F. Administrator
Originally Posted by Jeff92se
Damn how did I miss this thread. I just got done getting a remote and key from ebay. Great thread. Sticky please!
Thanks for the heads up Bryant.....I've posted a copy in FAQ/DIY forums too.
C.
chinee
04-19-2021 09:18 PM
mike730
01-12-2018 04:25 PM
zcherub
08-30-2015 05:04 PM
.cakestar
08-04-2015 09:05 PM
Quick Reply: key program - the alternative to the Infiniti ignition key.
