MyG37.com | G35Driver.com | My350Z.com | ZDriver.com
Show Your Support Become A Premier Member
Go Back   G35Driver > Tech Area > FAQ & DIY
User Name
Password
Register FAQ Members List Calendar Search Today's Posts Mark Forums Read
Thread Tools Search this Thread Rate Thread Display Modes
Old 11-28-2003, 05:26 PM
Msedanman's Avatar
O.F. Administrator
Clear Airbag Warning Light
In reply to:
god_of_cpu ()
11/28/03 04:15 PM
After installing an FM Modulator in my G35, I mistakenly turned the car on to test it out while the panels were still off and the airbag light started flashing cause the airbag cable on the passenger side was still disconnected. My dealer wanted to charge me $90 just to clear the code, which I refused purely out of spite cause I just bought the car from them 2 weeks prior.
After about 3 months of searching I finally found out how to reset the light and the clear the SRS diagnostic codes. This will only work if the airbag warning light is blinking on and off in a steady fashion and will only work if there is not currently a problem with the system and of course you should have a dealer look at it if you dont know the cause of the problem.
To reset the light simply turn the iginition to the on position, (you dont need to start it). All the lights should stay on for thier diagnostic check. As soon as the airbag light goes off, before it starts flashing, immeditatly turn the car off. Repeat this 3 or 4 times (turning to on then off) and the light should go away. Bam! saved yourself $90
read the below post by RamboRami for the proper/scientific way of doing this...
Many thanks to 'god_of_cpu' for sharing this with us.
GSM
GSM Silverstone Coupe
Edited by ramborami on 07/15/04 06:59 PM.
__________________
MSM
Old 07-15-2004, 10:49 PM
RamboRami's Avatar
G35driver.com Moderator
Re: Clear Airbag Warning Light
Here is the exact way to do it according to the service manual.
Basically it needs to be done 3 times to enter the Diagnostic Mode, then the fourth time keep the key in the ON-position to stay in Diagnostic Mode. Stay here for a few mode seconds. Then the fifth time you turn the key, it will clear the diagnostic mode and get the car back into User Mode. Here is the exact wording of this from the service manual:
HOW TO ERASE SELF-DIAGNOSIS RESULTS
After a malfunction is repaired, turn ignition switch OFF for at least one second, then back ON. Diagnosis mode returns to the User mode. At that time, the self-diagnostic result is cleared.
-Rambo
G35c-6MT-DG/Willow/HyperGround/BorlaExhaust/350Z-intake/AVIC-N1-double-din
Edited by ramborami on 07/15/04 06:54 PM.
__________________
'03 G35 6MT- still rollin'
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
Search this Thread:
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
Powered by vBulletin Version 3.5.2
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Copyright ©2002 - 2008, G35DRIVER.COM All Rights Reserved.
Terms of Service - Privacy Policy - JOBS
MyG37.com | My350Z.com | ZDriver.com | G35Driver.com
