Thread Tools | Search this Thread | Rate Thread | Display Modes |
2005 Rear Light Kit Install Guide
If you don't have it already, your going to need Adobe Acrobate Reader to open this page up.
http://psedog.com/G35_hosted_files/2...ghtInstall.pdf The install is very easy and doesn't require alot of time. PM me if you have specific questions that could not be answered in the DIY Special thanks too- psedog for offering up the resource to host this file.
__________________
03 IP 350GT >>> http://g35driver.com/forums/showpost...22&postcount=1 Last edited by G35papa : 12-19-2006 at 01:47 AM. |
Quote:
The http link doesn't work. |
Quote:
JMO.... But not a good idea, shouldn't have to register to see the DIY
__________________
the old - '04 G35 Sport 5AT ~~ the recently departed - Z4 ///M Roady ~~ the new - '08 G35S 6MT |
Original post edited and link now works
__________________
03 IP 350GT >>> http://g35driver.com/forums/showpost...22&postcount=1 Last edited by G35papa : 12-19-2006 at 01:48 AM. |
G35papa....
Thanks for the work on the DIY FWIW.... If I can offer one suggestion; on page 3 - instead of prying with the screw driver, just push the studs from inside the trunk. If necessary you can leave a nut on at the end & give it a tap. The nut protects the threads.
__________________
Great suggestion inTgr8r!
I've updated the DIY I appreciate the feedback.
__________________
03 IP 350GT >>> http://g35driver.com/forums/showpost...22&postcount=1 |
www.everythingg35.com
has them for $447.38 for the rear brake light set and like $60 for the reverse light set. They use to have the complete set (brake and reverse light set) for $447.38...........you may want to give them a call to see if thats the case again. I couldn't find a listing for the reverse lights.
__________________
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Display Modes | Rate This Thread |
