Show Your Support Become A Premier Member
Activity Stream: Show All | New Threads | New Posts | New Pictures | Popular Threads | Lonely Threads | Only Vendor Threads | New Picture Comments | New Profile Comments |
Go Back   G35Driver > Tech Area - V35 > FAQ & DIY
Sign in using an external account
Register Forgot Password?
Welcome to G35Driver.com!
Welcome to G35Driver.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join G35Driver.com community today!
submit to reddit
Thread Tools Search this Thread Rate Thread Display Modes
Old 01-11-2006, 10:16 PM
LCA575's Avatar
Points: 11,541, Level: 70
Points: 11,541, Level: 70 Points: 11,541, Level: 70 Points: 11,541, Level: 70
Level up: 73%, 109 Points needed
Level up: 73% Level up: 73% Level up: 73%
Activity: 0.4%
Activity: 0.4% Activity: 0.4% Activity: 0.4%
Garage is empty, add now
AACstyle AACstyle
G35 Sedan Headlight Removal Guide (3 Simple Steps)
I put together a little photo tutorial of how to remove the sedan headlights in order to custom paint and/ or install Demon Eyes.
Prep: Lay down a towel or in this case a rubber mat in front of the vehicle to protect the bumper from hitting the ground.
* Find a safe place to store all of the rivets and bolts you will remove from the vehicle.
Step #1: Tools Needed- (1) Medium/ Small Flat Head Screwdriver.
- Open the hood and locate the 7 plastic rivets holding the grille and bumper to the radiator support.
-With your flat head screwdriver pop up the rivet and remove it.
- Now proceed to the driver side and turn your wheel all the way to the right so you can access the fenderwell. Remove the 3 rivets in the fenderwell in the same fashion you did for the grill.
Step# 2: Tools Needed- 10mm Socket Wrench w/ Extension.
- Pull back the fenderwell (using the flat head screwdriver where needed) to expose the (2) 10mm bolts securing the bumper to the fender.
- Using your 10mm socket remove these bolts and put in a safe place.
- Reach into the fenderwell and remove the plug from the corner lights.
- Repeat this process on the passenger side.
- Now the bumper is free and can be pulled forward. **Add painters tape to the fender to protect from marks caused by the bumper**
Old 01-11-2006, 10:18 PM
LCA575's Avatar
Activity: 0.4%
AACstyle AACstyle
Step# 3: Tools Needed- 10mm Socket Wrench w/ Extension.
- Now that the bumper is pulled forward the 4 bolts holding the headlight in are exposed.
- With your 10mm socket wrench remove the following bolts:
Bolt #1-
Bolt #2-
Bolt #3-
Bolt #4-
- Now you can pull the headlight out and unclip the headlight harness.
- Put headlight in oven and repeat Step #3 on passenger side.
- Now install your Demon Eye Kit and VOLA!
Old 01-12-2006, 12:17 AM
Endless G's Avatar
Points: 6,580, Level: 53
Points: 6,580, Level: 53 Points: 6,580, Level: 53 Points: 6,580, Level: 53
Level up: 15%, 170 Points needed
Level up: 15% Level up: 15% Level up: 15%
Activity: 0%
Activity: 0% Activity: 0% Activity: 0%
Thanks for the info!!
These are great help
__________________
2005 6MT G35 Sedan SOLD!!
Wife's 2008 IS250!?!
Old 01-12-2006, 12:31 AM
That's freeeaaakin amazing!!! Can we see some pics with the demon eyes on your car at nighttime?
Old 01-12-2006, 01:30 AM
Points: 5,978, Level: 50
Points: 5,978, Level: 50 Points: 5,978, Level: 50 Points: 5,978, Level: 50
Level up: 14%, 172 Points needed
Level up: 14% Level up: 14% Level up: 14%
Activity: 0.4%
thanks!
Old 01-12-2006, 02:44 PM
LCA575's Avatar
Activity: 0.4%
AACstyle AACstyle
Quote:
I don't have a pic of the sedan at night yet but here is the coupe:
Old 01-12-2006, 02:49 PM
Points: 7,275, Level: 56
Points: 7,275, Level: 56 Points: 7,275, Level: 56 Points: 7,275, Level: 56
Level up: 63%, 75 Points needed
Level up: 63% Level up: 63% Level up: 63%
Activity: 0%
What's the deal w/ putting the headlights in the oven? Pls explain because I don't get it.
Old 01-12-2006, 02:54 PM
LCA575's Avatar
Activity: 0.4%
AACstyle AACstyle
Quote:
You put the headlights in the oven in order to open them up to custom paint or install Demon Eyes.
Old 01-12-2006, 03:24 PM
codeflux's Avatar
Points: 17,619, Level: 84
Points: 17,619, Level: 84 Points: 17,619, Level: 84 Points: 17,619, Level: 84
Level up: 54%, 231 Points needed
Level up: 54% Level up: 54% Level up: 54%
Activity: 4.2%
Activity: 4.2% Activity: 4.2% Activity: 4.2%
2011 Infiniti G37
Mods, STICKY please. this is an awesome DIY, demon eyes or not.
__________________
2011 Infiniti G37 Journey Sedan
Old 01-12-2006, 03:31 PM
Send a message via AIM to R2 V35 Send a message via Yahoo to R2 V35
Quote:
+1
Old 01-12-2006, 05:38 PM
Points: 7,592, Level: 58
Points: 7,592, Level: 58 Points: 7,592, Level: 58 Points: 7,592, Level: 58
Level up: 21%, 158 Points needed
Level up: 21% Level up: 21% Level up: 21%
Activity: 0.4%
What temp do you recommend setting the oven?
Old 01-12-2006, 05:47 PM
LCA575's Avatar
Activity: 0.4%
AACstyle AACstyle
Quote:
210, it is detailed in the Demon Eye install guide.
Old 01-12-2006, 11:58 PM
g35guy86's Avatar
Points: 8,131, Level: 60
Points: 8,131, Level: 60 Points: 8,131, Level: 60 Points: 8,131, Level: 60
Level up: 91%, 19 Points needed
Level up: 91% Level up: 91% Level up: 91%
Activity: 0%
2006 Infiniti G35
vq35guy
once you bake the headlight is it going to be hot to hold when you take it out or just warm? I have been very interested in the demon eyes but have been wondering about the oven part.
__________________
2006 G35 6MT coupe Diamond Graphite/Graphite with mods
Old 01-13-2006, 12:13 AM
Where did you get your demon eyes kit? Did you change any other bulbs or fogs while you were in there? is replacing the foglights much more elaborate than this?
thanks & hope my Q's aren't too noobish
Old 01-13-2006, 12:14 AM
Also, how does this effect visibility at night?
Thanks again
submit to reddit
Tags
07, 2006, bulbs, fender, g35, headlamp, headlight, headlights, putting, removal, remove, replacement, replacing, sedan, steps
Search this Thread:
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
G35Driver - Archive - Top
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2
Copyright ©2002 - 2008, G35DRIVER.COM All Rights Reserved.
Advertising - Terms of Service - Privacy Policy - JOBS
G35Driver.com | My350Z.com | MyG37.com | ZDriver.com |
Everyone's Contact Details
