MyG37.com | G35Driver.com | My350Z.com | ZDriver.com
Show Your Support Become A Premier Member
Go Back   G35Driver > Regional Forums > Groups & Clubs > Florida G Club
User Name
Password
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Register FAQ Members List Calendar Search Today's Posts Mark Forums Read
Florida G35 Club Sponsor
Thread Tools Rate Thread Display Modes
Old 07-24-2009, 07:28 PM
Sen's Avatar
Sen Sen is offline
Off to fight crime?
Alignment/Brake Problems
Hey guys, maybe some gurus could offer some advice.
The symptoms:
1) Pulsating braking at low speeds. Seems to pulse with the wheel revs. Not noticeable at higher speeds.
2) Pulling to the right. Not noticeable at lower speeds. I'm almost certain it's not due to the natural slope of the road.
The facts, according to my alignment shop (Firestone). Just purchased lifetime alignment, and did a free brake inspection.
1) Alignment is spot on, according to Firestone. Although, you cannot adjust the camber on the fronts. I'm not sure if camber is off, but toe is okay, according to them.
2) Brake pads are uneven in the rear, according to Firestone. 50% worn on left side, 75% worn on right side. Fronts are fine.
3) Rotors are not warped.
They suggested going back to the tire shop, because I noticed the pull shortly after getting two front tires put on. Discount Tire adjusted the front pressure to be even for both tires. Didn't work. They switched the front tires. Still pulls to the right.
The easiest option is to go the dealership. But if I can fix it myself, I would like to do that. Also, the lifetime alignment agreement I just purchased makes it frustrating to still have to go to Infiniti.
So here are my questions:
1) Uneven brake pad wear a cause/symptom of pulsing brakes? My first thought was warped rotors and I was actually prepared to replace them.
2) Could the two problems be related? My right rear pads are worn more, and my car is pulling to the right...
3) The Firestone I've gone to is the one on Lake Underhill at Chickasaw. Anyone have any experiences there? Just wanna make sure their advice is sound.
__________________
Florida G Club
2007 Black G Coupe, 6MT
Old 07-24-2009, 07:38 PM
slackerx1x's Avatar
get your brake system flushed. Have firestone or whoever do a full flush on your lines and all. might be something restricting the fluid flow on your front or rear driver side brake line, causing a pull to the right, and might explain uneven wear. Im not a certified mech. but I do work on Helicoptor brake systems... so, its just a idea, let me know the outcome. I would have guess warped rotors first... Oh and ***BTW I have had a few drinks, pre-gaming before tonight lol, so if i do not make sense, that is why.
__________________
The Ride- 05' G-Coupe 6MT...The Bike- 2003 TL1000R-Modded
Old 07-24-2009, 08:52 PM
blAk mAx's Avatar
I'm Rick James, bitch
2004 Infiniti G35 Coupe
may not be your problem but just a FYI. If while driving you feel a wobble in your wheels that comes when you slow down and leaves when you speed up , you should pull over and check your lug nuts!!
__________________
95 modded maxima , 04 G35 coupe -- ISIS true dual exhaust from enjuku racing, 20" MRR, 350z S-tech, Ichiba camber kit, V1, z-tube, pop charger, ground wires, batt cover, iphone
www.myspace.com/OrlandoG35club
Old 07-24-2009, 09:19 PM
Sen's Avatar
Sen Sen is offline
Off to fight crime?
Yea, flushing the lines seems like a good place to start.
And the pulsating is only when I use the brakes.
__________________
Florida G Club
Old 07-26-2009, 09:56 AM
does the car pull while driving or while braking? i am not too sure that this is brake related. seems more like suspension, alignment, or tire issue. are your tires directional???
Old 07-26-2009, 05:04 PM
Sen's Avatar
Sen Sen is offline
Off to fight crime?
It pulls while driving, not braking. I think it's the alignment, but they said it was in spec. Had it done twice. They thought it might be tire pull, but I had them cross rotated, and it still pulls in the same direction. And yes, the tires are directional.
__________________
Florida G Club
Old 07-26-2009, 05:35 PM
Your car is only 2 years old. Let the dealer check it out under warranty. you may have a stuck caliper in the rear. It has happened before.
Depending on your miles, I'd turn the rotors to see if that helps too.
__________________
Sean
Florida G Club '03.5 Caribbean Blue 5at Sedan w/ a few mods, '04 Laser Red 6mt Coupe w/ more mods, 06 FX35 bone stock
Old 07-26-2009, 05:46 PM
2005 Infiniti G35
Send a message via AIM to oyoquem
Does it constantly pull to the right? Or do you drive and it pulls to the right all of a sudden on different occasions?
__________________
Ivory Pearl 2005 G35 Coupe 6MT - Kenstyle Rear, Top Secret Front, JWT Pop Charger w/ Z Tube, Apexi WS2 Exhaust, 5/16 MD Plenum Spacer, 20" XXR 006 Wheels, Stillen Sways, 20% tint, Nismo Shift Knob, Black OEM Grill, JDM Clearcorners + LEDs, LED City Lights
Old 07-26-2009, 06:49 PM
Sen's Avatar
Sen Sen is offline
Off to fight crime?
I actually like the warranty idea. Didn't think even think about that.
It pulls gently, but steadily. Just as if the alignment is off. It's just a strange coincidence that it's pulling the right, the alignment is fine, but I have uneven pad wear. And the pads on the right are more worn than the left.
__________________
Florida G Club
Old 07-26-2009, 09:28 PM
A lot of brake problems are not usually covered under warranty because of the wear nature of brakes. They're supposed to wear down. However, abnormal brake problems, like yours, are a safety concern and should be covered by any dealer, especially with a pulling problem.
Be sure to call and line up a loaner car too.
__________________
Sean
Old 07-26-2009, 10:02 PM
CaribbeanBlue's Avatar
Teh Redhead
2003 Infiniti G35 Coupe
+1 If you take it to Orlando Infiniti, make sure that Sarah is your service writer and Jason is your tech.
__________________
Florida G Club, Central FL Director
2003 Caribbean Blue 6MT G35 Coupe | HKS | JIC | Tein | SPC | Fidanza | Racing Hart | Brembo | Top Secret | Ings | Greddy | 06 Projectors I shift in heels
Old 07-26-2009, 11:10 PM
blAk mAx's Avatar
anyone else will screw you !!!!!
__________________
Old 07-27-2009, 08:18 AM
I always go to Sarah too. She used to have a modded out Scoobie that got wrecked.
__________________
Sean
Old 07-27-2009, 10:28 AM
Teh Redhead
Yeah and now she drives an M coupe I think... lol
__________________
Old 07-27-2009, 05:25 PM
m coupe???
bmw???
or did i miss something...
Tags
2003, 2004, 2008, alignment, brake, brakes, causing, g35, infiniti, pad, problem, pulsating, pulse, wear
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
G35Driver - Archive - Top
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Copyright ©2002 - 2008, G35DRIVER.COM All Rights Reserved.
Advertising - Terms of Service - Privacy Policy - JOBS
MyG37.com | My350Z.com | ZDriver.com | G35Driver.com
