| New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login |
Thread Tools | Rate Thread | Display Modes |
WTF? 267hp?
WTH is going on. Last time I got dynoed, I was at 267 hp/300 lbs torque. at 6lbs boost. I should be alot more than that. They told me I need 440cc injectors and a fuel return system to get over 300. Its hard for me to believe that with twin turbos, 380cc injectors, greddy full exhaust, plenum spacer and a tuned UTEC that I only have 267 rwhp.
Quote:
__________________
Quote:
What kind of dyno was it? Either way, a VQ35 TT should be no where near there. I would question the tuner/installer of the turbo's & EMS and how much experience they have on the VQ35DE if they can't seem to find the real problem.
Quote:
Twin turbos mean nothing; the volume of air and the amount of fuel being burnt will determine your power. Your tuner is correct; it looks like your injector's duty cycle is being maxed out. |
you're putting shaq in bed with a 14 yr. old chinese gymnast.
__________________
LR G CoupeBlack Everything Else
I'm 375.2whp with 550cc injectors
Well to the O.P, do you have supporting mods? (Exhaust etc.) I hope so, and yes definitely get new injectors, and i dont know maybe a new tuner
__________________
TEAM
O U T C A S T Obsession, Chivalry, Gallantry OCG Pride |
Well, currently my performance mods are:
UTEC Technosquare reflash Power Enterprise Twin Turbo kit - 6lbs (10 max) 380 CC injectors (440cc injectors currently being installed) AAM fuel return system (Currently being installed) Aeromotive fuel pressure regulator NOS intercooler sprayer Skunk2 Racing plenum spacer Greddy Blow off valve Greddy Full true dual Exhaust Test Pipes AEM Wideband A/F walpro fuel pump AAM told me that with this set up, I should be upper 300s |
who is the tuner?
__________________
G Sedan |
Quote:
nah AAM is too far away from me to tune. RS Motors in MN is doing the tuning for me. It is an AWD dyno too.
must be a mustang..
__________________
G Sedan |
Same kinda issue I had. Changed injectors 3 times: 380 to 550 to 720cc. They finally got tired of it and just slapped some huge ones in there and said, "there, you shouldn't need to worry about it for awhile". They also put in a return fuel system, but I didn't notice a difference other than a little smoother stop and go driving.
There was someone else around here with a Vortech claiming only 300whp. Do you know how to datalog with the UTEC? I would say with the injector issue fixed you should have NO problem hitting near 400whp, the PE kit is really nice!
__________________
SenBou.com| ProCharger : TurboXS : Data System : Seibon : Toyo : Valvoline : DEFI : Ro_Ja : SGP Racing : Dip-Tech.net
Gawd, I hope it gets fixed - dumping this kind of money into a ride to only get 267 - kind of a heartbreaker
what kind of % difference is the awd dyno gonna give me anyway
I'm on stock injectors at 355whp, weird that you can't even get it above 300whp regardless of the size of injectors. Tell us more info about your setup...
__________________
Relentless Autosports G35 Twin Turbo - Built 5AT - SGP Valve Body - JWT - Fast Intentions - Megan - NISMO - GReddy - Defi - Koyo - Nitto Need cams? FS: JWT S1 Cams Brand New |
| Tags |
| 380cc, deatschwerks, g35, injectors, reflash, technosquare |
| Thread Tools | |
| Display Modes | Rate This Thread |
