MyG37.com | G35Driver.com | My350Z.com | ZDriver.com
Show Your Support Become A Premier Member
Go Back   G35Driver > Tech Area > Engine, Drivetrain & Forced-Induction > Forced Induction
User Name
Password
Register FAQ Members List Calendar Search Today's Posts Mark Forums Read
Thread Tools Search this Thread Rate Thread Display Modes
Old 07-16-2008, 11:14 AM
Does the Greddy 350Z FMIC fit the G35?
I've searched both here and my350, can't find a confirmation that this will fit Ok.
Some say the core doesn't fit, some say the piping is off and needs to be modified. All I can tell from comparing the Greddy Instructions for the G35 and 350 is the washer fluid relocation.
I just need confirmation from anyone that has installed the 350Z TT with FMIC on their G35.
I know TTrank has done this on his Sedan, I have a coupe.
Much Appreciated.
Old 07-16-2008, 02:37 PM
2slo2bfurious's Avatar
The intercooler and the majority of the pipes are the same, its just 1 pipe that makes any difference, and it can still be "persuaded" to fit. GL!
Old 07-16-2008, 02:52 PM
THANK YOU! Do you know this from experience? Persuaded as in fabrication work, or alot of pushing and pulling?
Man getting answers from people is like pulling teeth sometimes LOL
Really appreciated, especially since the 350 TT Kit is in my basement and going on my G in 2 weeks LOL.
Old 07-16-2008, 03:20 PM
No fab work just a little pushing and pulling . Yes, my kit is a 350z kit, the pipe right after the MAF housing touches the fender liner a little, its a tight fit, but it works fine. Oh, and you can't bolt up the one charge pipe to the engine that feeds the intercooler from the driverside turbo, the flange isn't long enough (don't need to anyways, its not going anywhere or rubbing on anything).
I also suspect that the pipes are a tight fit because I am still using my crash bar, if you removed that like you're supposed to, maybe the first pipe I was talking about would have no problem at all.
Old 07-16-2008, 04:04 PM
Wow, thanks for the info. I wish this was in a sticky or FAQ cause Im sure we aren't the first to go through this, and won't be the last.
Old 07-18-2008, 04:41 AM
ILLMATiC G35's Avatar
iLL what!?
yes the 350z fmic fits.. just like in previous posts.. you have to fab a different pipe to "work"
__________________
iLLMATiC
Old 07-18-2008, 01:02 PM
sharif@forged's Avatar
G35DRIVER.COM SPONSOR
As mentioned, it will fit...we've done it here. A little persuasion is all it takes.
The washer res is a little different too, since the Z has two washers and the G only has one. But how needs washers anyways.
__________________
HKS Pro Dealer (FCON Vpro BASIC Install/Tuned $2990), Certified: Fcon, Haltech, MoTec, AEM| www.forgedperformance.com | Sharif@ForgedPerformance.com Large Inventory of the BEST VQ35 parts: Only stuff that works..PERIOD!
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
Search this Thread:
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
Powered by vBulletin Version 3.5.2
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Copyright ©2002 - 2008, G35DRIVER.COM All Rights Reserved.
Terms of Service - Privacy Policy - JOBS
MyG37.com | My350Z.com | ZDriver.com | G35Driver.com
