MyG37.com | G35Driver.com | My350Z.com | ZDriver.com
Show Your Support Become A Premier Member
Go Back   G35Driver > Tech Area - V35 > Engine, Drivetrain & Forced-Induction > Forced Induction
User Name
Password
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Register FAQ Members List Calendar Search Today's Posts Mark Forums Read
Thread Tools Rate Thread Display Modes
Old 05-04-2004, 10:12 AM
Re: Vortech whistling woes
I did something similar. I initially went to Home Depot to find the coupler and PVC elbow that justICE used. I couldn't find the elbow with threads on outside but did find a couple of similar ones w/o threads. However, I ended up finding a radiator hose with a 90 degree elbow and I cut it down to size instead. I then used a PVC coupler to attach the hose to the K&N filter. It drastically reduced the whistle, but there is still a slight one left (but it is not nearly as annoying!). The sole purpose of this set up is to slightly disrupt the air flow. In fact, if I just put one finger infront of the airflow (without anything attached) the whistle went away completely.
04 G35c DP/Willow, aero, prem, guards...
Vortech S/C
R/T cats
Stillen exhaust
JWT clutch & flywheel
Eibach sways
clear corners
brake reservoir cover
grounding wires
__________________
**FOR SALE** 04 G35C 6MT Desert Platinum -17K miles, vortech + Ballistic Motorsports built motor + extras, 2.87 pulley(tuned by Holyroller Dyno), 450+ whp/400 wtq
Old 05-05-2004, 07:52 AM
Offtopic, but does the Vortech make the same BOV sound as a turbo?
Twilight Blue G35 Coupe 6MT
Premium - Nav - Aero - Trunk Mat
Injen CAI
Old 05-05-2004, 05:52 PM
Hey Kz did you put filter oil on it? I noticed mine still had a very slight whistle untill I put just a tad of filter oil on it.
"I'm not saying you're full of BS, per se" - Zimbo
-JustICE
Old 05-05-2004, 06:14 PM
No JustICE, I didn't. Maybe I'll try that next (I have K&N filter oil at home). Thanks for the heads up! I'll let you know if there is a difference.
-KZ
Vortech S/C
R/T cats
Stillen exhaust
Eibach sways
clear corners
grounding wires
__________________
Tags
coupler, intercooler, kragen
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
G35Driver - Archive - Top
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Copyright ©2002 - 2008, G35DRIVER.COM All Rights Reserved.
Advertising - Terms of Service - Privacy Policy - JOBS
MyG37.com | My350Z.com | ZDriver.com | G35Driver.com
