MyG37.com | G35Driver.com | My350Z.com | ZDriver.com
Show Your Support Become A Premier Member
Go Back   G35Driver > Tech Area - V35 > Engine, Drivetrain & Forced-Induction > Forced Induction
User Name
Password
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Register FAQ Members List Calendar Search Today's Posts Mark Forums Read
Thread Tools Rate Thread Display Modes
Old 08-11-2009, 01:40 AM
Canadian's Avatar
Canada, eh?
2006 Infiniti G35
Send a message via ICQ to Canadian Send a message via AIM to Canadian Send a message via MSN to Canadian Send a message via Yahoo to Canadian
Quote:
Originally Posted by Chef-j View Post
How do you know for sure if you are car is over heating or not. What was the temp?
I do not have an experience with nismo thermostat, but by research i read many people says it doesn't help.
I can tell from experience that it DOES help.
__________________
Relentless Autosports G35 Twin Turbo - Built 5AT - SGP Valve Body - JWT - Fast Intentions - Megan - NISMO - GReddy - Defi - Koyo - Nitto
Need cams? FS: JWT S1 Cams Brand New
Old 08-11-2009, 07:42 AM
Send a message via MSN to Chef-j
Quote:
Did you installed radiator at same time? Do you know how much did it help? (Beside shows on stock temp meter thing )
Edit: don't get me wrong, I'm trying to make cooling list for myself.
Op, If you are runing v2, have you think about doing oil cooler? And any update?
__________________
Vortech Z: Jared@uprev Tuned
Old 08-11-2009, 04:08 PM
Canadian's Avatar
Canada, eh?
2006 Infiniti G35
Yes, I installed a radiator at the same time. I can tell the nismo thermostat does help because I have an coolant gauge which is dead on accurate to the ECU temp. As soon as the thermostat opens my coolant gauge stays dead even at 175 degrees. If I just had a bigger radiator, the gauge wouldn't read at 175, it would read wherever the stock thermostat opens.
__________________
Old 08-11-2009, 07:27 PM
That's good to know, thanks.
__________________
Old 08-16-2009, 12:03 PM
My mechanic doing the build on my car is a certified Master Nissan Tech. Just the other day I was asking him if this NISMO thermostat made a difference or not. He said yes...in short that thermostat allows the engine to run a full 10 degrees cooler with a stock radiator. Add a larger core radiator and the decrease in temp is more significant. IMO the NISMO thermostat is a must with FI...so is a larger core radiator. You can never have too much cooling.
__________________
03 BS G35C 6MT - Team OUTCAST//APS Extreme TT//Cosworth VQ35DE//Corner 3//Treble Racing
Old 08-19-2009, 07:34 AM
Thermodynamically all that really solves the situation is to increase the coolant volume by a factor that mimics the power increase.
If you increase by 30%, increase coolant volume by 3-4 quarts.
__________________
http://www.t3auto.com/
Old 09-13-2009, 03:46 PM
I drive my vortech revup every day, even in the week of 95 degree weather stuck in chicago traffic with AC on, I have no issues temp stays the same.
Just a tad below halfway on the stock gauge in the dash.
2006 30k miles
__________________
06 6MT-Vortech-JWT-TEIN CS-SPC
Tags
2003, 2005, 350z, at, body, escort, g35, heating, infiniti, infinity, overheat, overheating, stage, valve, vortech, x8500
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
G35Driver - Archive - Top
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Copyright ©2002 - 2008, G35DRIVER.COM All Rights Reserved.
Advertising - Terms of Service - Privacy Policy - JOBS
MyG37.com | My350Z.com | ZDriver.com | G35Driver.com
