greddy tt questions
Old 03-23-2013, 12:17 PM
biggerandbetter's Avatar
greddy tt questions
I have a few questions on this kit. I am looking at a greddy tt kit from a 2003 350z for my 03 g35. It is intercooled, will the kit bolt on correctly? I just dont kno if the piping is the same.
Second question is power. It is the 18g kit and i am shooting for 650whp. Am i safe to stay at stock compression, or do we really have to go down? I am going wiseco pistons, eagle rods, rebalance crank, new bearings, etc. also doing a mild cam, springs, and port job.
I would really appreciate any guidance. I am currently procharged and want to go bigger.
Old 03-23-2013, 12:51 PM
Pepper's Avatar
You have a lot of reading to do. http://my350z.com/forum/forced-induc...for-noobs.html
Old 03-23-2013, 02:18 PM
I know what im talking about good sir. All i am asking is if it will fit with that piping. I would also know if i can stay at stock compression on forged internals. On e85 i should be able to avoid detonation i believe on a good tune. The thread you linked explains how each work and the pros and cons, which i know. Thanks though, i just want to know if this will work
Originally Posted by Pepper
Old 03-24-2013, 07:10 PM
Pepper's Avatar
#1 Yes, the kit is virtually identical.
#2 Stock compression is no good for 650 RWHP. Gotta come down quite a bit.
Old 03-24-2013, 07:44 PM
guitarrocker98's Avatar
Of build the motor up quite a bit...
Old 03-24-2013, 09:04 PM
I just know that the radiator shroud is slightly different between the z and the g35. I am going forged, just didnt know which compression to stay with. Knowing it is forged either way, I would think I could run more boost on 8.5:1 or less on 11:1 th achieve the same hp levels. But thats why I ask here.
Old 03-24-2013, 09:16 PM
Pepper's Avatar
8.5:1
http://www.importpartspro.com/cpvqtupini35.html
Old 04-01-2013, 08:38 PM
Gdoser's Avatar
The elbow of the cooler side of intercooler is different that's it
Genki (04-06-2013)
Old 04-08-2013, 01:59 PM
G ZILLA's Avatar
yes high comp on e85 is fine, just ensure you make your complete fuel system e85 friendly, that shizzil will eat up gas rubber bushings in no time.
I wanted to go stock comp on my Vortech, tuner was against it. I should of stuck to my guns.
Old 04-08-2013, 02:45 PM
Sylvan lake V35's Avatar
For that kind of power I would at least drop it to 9.5:1, even with L19 head studs I would be worried about lifting the heads at 11.1:1.
Machine Head
19 Inch
03-16-2016 08:55 PM
yosip1115
Forced Induction
01-28-2016 02:51 PM
INVADER_6MT
09-01-2015 10:19 PM
G35Sask
Intake & Exhaust
16
08-05-2015 10:17 PM
Quick Reply: greddy tt questions
