Thoughts on current build!
hi guys just wanted thoughts and advice! so i got my car pro charged a few months back, i put in 440cc injectors and a 225 walbro fuel pump, it has a cutback exhaust and aem air intake, coper iso md spacer, up rev tune, and 3 gauges sideband a/f, oil demo, and boost.
the supercharger has a custom fabbed bracket so it dosnt break belts and it has a 12psi pulley so i wanted to tune it close to the 400 to the wheels mark but it blew a head gasket on the dyno just my luck.... so a few months later here i am and the car is currently all apart at a shop having cometic head gaskets, wiseco pistons 8: 8 :1, and eagle rods put in, also new slotted rotors and test pipes while its there.
I just want feedback on the build so far, what i could add while its apart to add hp or just be good to do at this point i kinda want to look into e85 and also want to get an oil pressure gauge and mac said they hope to have it at close to 430 to the wheels for my dd
forgot to mention i did get ACL race bearings! a rev up oil pump cool will have to look into it! thanks!
Timing chains? Front and rear main seals...arp headstuds... with pistons and rods on a high oct mix you should be able to break 500whp on a dd. There's a few people on here in the 600+ neighborhood that can probably give you better advice. your 440 injectors may become the limiting factor.
unique G (07-16-2013)
Tomei expreme test pipes with my exhaust sound good. And as stated above 440 injectors will not get you to 500whp. There are plenty of members who have injectors that would meet your needs. Just make sure they're flow tested or have them flow tested after purchase. You can save a few $$$.
+1....superchargers are even worse on fuel than turbos, since the engine has to work harder to spin the blower; expect around 750cc or more to hit 500whp...
For that matter, it'll take some work to get a procharger on a VQ to 500whp...you'll have to work around the belt slip/breakage, and potentially running out of blower even if you overspin it by pullying it down (ie blower efficiency)...
unique G (07-17-2013)
