Gready twin turbo kit information
Does anybody know do you have to remove the a/c compressor can relocate the power steering pump or can you get away by leaving it there to install AG ready twin turbo kit with GT28Rs turbos its on a 04 G can you reroute piping to make it work
Posted from G35driver.com App for Android
I've got the regular 18G turbos and everything is a very tight fit but none of those need to be relocated. If you're referring to Meatbag's turbos that you were considering buying, I believe he's using the same compressor housings and just upgraded the turbines. So everything should fit fine. He had to relocate some things because he had 3" piping coming into the turbos, not the smaller piping that comes with the kit. Rerouting piping will require custom fabrication, time and money.
yosip1115
Forced Induction
01-28-2016 02:51 PM
