Boost Leak?
Boost Leak?
Hey guys,
Would love to pick everyones brain. I decided to stick with my G18s and just turn up the juice, but I think I've got a boost leak-- let me know if this makes sense.
Went from AT to MT with an HKS SSQV, there is no adjustment on an HKS (famously) but it was the only BoV I could really use with my AT and not stall at low RPM.... Now I was stalling at Low RPM when I moved to a MT.
We drilled a VERY small (3/16" ish) hole in my throttle body, and it cured my car diving for 300 RPMs everytime I hit the clutch (and ultimately stalling my car in a lot of situations).
So recently: I upgraded my wastegate springs, took the OLD HKS SSQV off and put a Tial 50MM with appropriate spring. I could only run about 16.5 PSI on the dyno and made 589 torque and about 575 HP ( No dyno sheet to show you)... Now when I drove it, the BoV sound was delayed by fluttering / surge.
I THINK, that hole in my TB is messing with my vacuum and boost at high boost, and now that my BoV has adjustability, I can use that instead of a hole in my TB.
Thoughts?
Thoughts?
RemmyZero
V36 DIY
04-23-2018 11:13 AM
