Need help/advice: Greddy FMIC fabrication and single VS dual decision
Old 08-17-2015, 10:18 AM
yosip1115's Avatar
Hey guys,
I'm in the middle of a greddy build and hit a road block.
My used kit came with two JWT style intercoolers (lets say they match the dimensions of the JWT ones to simplify things). The kit did not come with piping to hook these up. It came with the piping that matches the greddy style single dual inlet 23x11.5x4.5" intercooler that comes with the kit.
A aftermarket bumper will be purchased once I make the decision to stay twin or go single.
I'm wondering what I should do here. I'm trying to find an affordable option (greddy FMIC kit is $1250+)
I can figure out the piping thing regardless of what route I take but I would like to minimize the amount of pipe fabrication I need to do because of time... Just don't know if I should ditch these twins or not and if I do where to go for an affordable intercooler that matches the greddy dimensions. I am about to call speed force R&D to see if they can help. I also heard spearco makes custom intercoolers but no way will that be cheap.
http://turbostore.com/twtuin313co2.html
Found this one but it is way longer than the greddy one, think it will work?
Anybody have an opinion/insight?
Thanks!!
Old 08-17-2015, 10:29 AM
DigitalDeviant's Avatar
Originally Posted by yosip1115
Hey guys,
Thanks!!
Look for something like this. Then you won't need the turbo y pipe.
Godspeed makes one for under 200. But this is better quality.
http://www.treadstoneperformance.com/product.phtml?p=67750&cat_key=63&prodname=TRTT+Ser ies+Twin+Turbo+Intercooler++1000HP
Old 08-17-2015, 10:35 AM
yosip1115's Avatar
http://www.treadstoneperformance.com...cooler++1000HP
ah like the APS kit. Do you know if I'll have a hard time mating the greddy charge pipes to this style? This one is the way to go, it is almost a straight shot to the TB.
Thanks for the speedy reply.
Old 08-17-2015, 10:37 AM
Same FMIC i am using as i don't have the turbo Y pipe from the greddy TT kit. You'll need some fabricated, but should be fine.
yosip1115 (08-17-2015)
Old 08-17-2015, 11:23 AM
yosip1115's Avatar
What are your thoughts against this one? I'm thinking it may be a good option if the inlets/outlets line up. That way I don't have to make the hot and cold side piping. Not positive it will line up but the core dimensions are only off by .5" from the greddy one.
http://turbostore.com/twtuin313co2.html (same link I provided above)
Old 01-28-2016, 02:29 PM
eZg's Avatar
eZg
eZg is offline
Yosp
Did you ever get a FMIC made?
Old 01-28-2016, 02:40 PM
yosip1115's Avatar
Originally Posted by eZg
Yosp
This one bolted right up, just made brackets and got larger couplings. Realllllly sweet actually. 850HP rated... Not bad. It isn't a vertical style or anything but it made great power and runs very cool, not that it has much to cool... The hot side is cold.... Honestly I am amazed I didn't have to modify any pipes. I believe DrifterX posted up the Greddy IC dimensions in my build thread. Looking back, the treadstone one is ugly as hell ha. Also my kit does not have a turbo Y pipe, there are two charge pipes coming straight from each turbo to the IC. Seems there may be a few variations of the Greddy kit...
Old 01-28-2016, 02:43 PM
eZg's Avatar
eZg
eZg is offline
WOW!! Glad I asked.
I'll checkout your build thread now.
Thanks
Old 01-28-2016, 02:51 PM
yosip1115's Avatar
WOW!! Glad I asked.
Thanks
I lied a bit, I had to snip just a tiny bit of aluminum with tin snips to get the hot side pipes to slide into the couplings once I clamped them onto the IC. Really not a big deal. I believe I centered the IC too, no offset at all left or right.
I'm very glad this was of help to you. It was a real road block I ran into for a few weeks. Good luck!!
g.spot
05-09-2016 10:54 PM
Red G Coupe
Tuner & Dyno
01-14-2016 01:13 AM
Learned Hand
10-01-2015 09:02 AM
9tray turbo
09-29-2015 10:22 PM
Quick Reply: Need help/advice: Greddy FMIC fabrication and single VS dual decision
