| New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login |
Thread Tools | Rate Thread | Display Modes |
#286
Awesome, that's for this detailed thread. I just sent this to my wife so she can STUDY before on the JOB TRAINING!
__________________
2006 Athens Blue 6MT Coupe / MD MRev2 / MD 5/16 ISO Thermal Spacer / Z-Tube / JWT Pop Charger / SxExCx Grounding Kit / Clear Corners |
#287
ok so you know how the g35's clutch disengages half way when releasing the clutch pedal? so you dont have to fully push down the clutch pedal to shift right? no extra wear occurs on your car because you do so? what about if im racing? should i fully engage the clutch or just slightly
#288
Asking for trouble.
__________________
Those who hammer their guns into plows will plow for those who do not.--- Thomas Jefferson 2005 DG MT6 Sport Sedan Premium, MREV2, NISMO R tune CAI, M-45 sport wheels w/Falken TS115, Hotchkis bars, 350Z springs, StopTech Stage II kit, etc. |
#289
Quote:
__________________
#290
lol instead of calling me out on the noobness could i just get an answer? yes i am new to stick which is why im asking
#291
I gave you the answer. I have 85000 on my original clutch, I wouldn't do that.
__________________
#292
I never use my clutch/tranny to slow down on a downshift, only to speed up (so always rev matching). The way i see it, brake pads are cheaper than clutches and labor to install them!
__________________
Time - Effort - Sweat - Research - A Little Blood - Several Cuts and Scrapes |
#293
AMEN Brother!
__________________
#294
Our 6mt is definitely quirky, a tad tougher to be smooth with :\ That's for sure after driving all sorts of imports plus tracking, even in comparison with my 00 Max SE and Stage II STi. That high engagement (I adjusted as much as possible for lowered travel) and the snappy spring action (you could feel when pressing the clutch pedal with hands) are the cause. Taking off from a light and 1-2-3 shift takes a bit to be smooth with. What I do before each of these low gear shifts is to quickly bring up the pedal from the bottom to just somewhere 'before' the engagement point, then slow the travel quite a bit at the take up point. This is part of 'finding' the take up. Oh yeah, takes practice on the 6mt, but feels much more seamless betw gears. I'm not riding the clutch, the actual engagement is just like on the other cars. But hey, please depress your pedal all the way down, it will save your plates.
__________________
08 G35S - PREMIUM / NAVI / TECH - 6MT - Blue Slate/Graphite + 05 WRX STi (Track/TT) 6MT Black Pearl Cobb Tuning/Cusco/Autopower/KW/Whiteline
#295
Quote:
yea exactly, it seems so much more seamless when i dont push done the clutch all the way, it feels like an automatic if i shift correctly. what could go potentially go wrong if i continue doing this? ( legit question) |
#296
great write-up, chilibowl.
i do rev match (as explained by chilibowl in the original post) to speed up and I am quite good at it. But, i use the double clutch method and brakes to slow down. i do want to learn the proper way to use brakes and downshifting together to slow down... if I try to do it, the car jerks.... any tips on doing that the proper way?
__________________
syshs G Last edited by syshs; 09-30-2009 at 01:59 AM. |
#297
Nice write-up. There is one thing though.
I didn't read the entire thread (because it's long and I'm lazy) so I don't know if this has been covered, but if so, it still needs to be edited in the original write-up. Quote:
__________________
03.0 IP Sedan on Z springs. Check out my website: http://www.NFSPMotorsports.com |
#298
Quote:
__________________
'05 Black Obsidian G35 6MT Sedan - slightly modded with a mild drop and cat back exhaust |
#299
Quote:
__________________
| Tags |
| 6mt, correctly, drive, g35, g35driver, mt, rpm, shift |
| Thread Tools | |
| Display Modes | Rate This Thread |
