| New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login |
Thread Tools | Rate Thread | Display Modes |
#31
if you're new to MT, this site explains things pretty well: http://www.standardshift.com/faq.html
#32
Quote:
__________________
'06 DG Coupe 6MT | INJEN CAI | 15% Llumar | VLEDS | JDM Clear Corners | TEIN 350Z S-Tech | 3000K HID Fogs | Hardwired Beltronics Pro RX65 | Batmobile G35HL1 Overlays | |
#33
Good writeup, but honestly it is just a clutch and isn't that expensive to replace if you are a little hard on it.
__________________
'05 G35 Sedan Sport pkg / 350z Tein H-Tech / Tokico D-Spec / Stillen Sway Bars / Bumper Plugs / K&N Panel / VLEDs / 18" 350z winter wheels - Pirelli 240 Winter Sports / OEM Z-Tube / Hardwired V1 / Hawk HPS |
#34
Quote:
__________________
#35
Quote:
__________________
Quote:
#36
ima noob, good write up!
__________________
o7 6mt IP coupe, stock "FOR NOW" waiting to put on Tokico-Hotchkis-H&R-NRG
#37
Quote:
#38
Quote:
__________________
#39
ONE more question lol
do u recommend putting it in neutral when the car is rolling? like down a hill..or coming to a red light (with a slight downhill of course)...because my dad says its bad for the brakes (obviouslY) and u should just keep it in gear. because my route going home..there is this really windy road going downhill..and u can reach to about 50 easily without ever steppin on the gas..so if its in neutral and its goin at 50 and i need to stop..would that be really bad for the brakes? or is it ok to do? |
#40
once you get good, try doing all your upshifting and downshifting without using the clutch at all!!!! Of course, you need the clutch for starting out in 1st gear. after that, if you know what you are doing and can matches revs between gear, you can perform clutchless shifts without any gear grinding.
btw, these are normal shifts, not speed shifting.
__________________
Twin Turbo Sedan - DIY it!!!!! |
#41
IT is ok, but u are gonna change the pads more often.
__________________
Quote:
#42
Quote:
__________________
i drive an 06 but i tell everyone its an 07 |
#43
always have the gear engaged....otherwise you have less control. only push the clutch in right before you are about to stop. I like to downshift as I am slowing down and use engine braking.....it is not necessary, but just part of the fun of driving a manual tranny.
powershifting will result in faster times at the dragstrip, but it is brutal on the tranny!
__________________
#44
Whenever I shift too hard, the floorboards fly out.
__________________
Coupe 19s ~ Hotchkis swaybars ~ Crawford V5 plenum ~ V1 hardwire kit ~ Autoenginuity OBDII & Nissan enhanced ~ Z front/coupe rear springs w/ Koni adjustable shocks ~ TS F-Spec reflash |
#45
Powershifting takes lots of practice, because you must be VERY quick. When powershifting, as soon as you push in the clutch, the revs will spike all the way to redline/fuel cutoff, and if youre not quick enough, you will be simply at fuel cut for about a second and you will actually lose time. Also, when slowing down to come to a light, I downshift and 3rd is as low as I go. Cruise to the light in 3rd and just brake the last few feet while putting it in neutral once u come to a full stop. You should also always be in gear. If youre going down hill, stay in very low gear, such as 2nd or 3rd, and the engine will hold itself from gaining too much speed. Downhill braking eats up brakes, ur better off just using the engine to brake.
__________________
'06 DG Coupe 6MT | INJEN CAI | 15% Llumar | VLEDS | JDM Clear Corners | TEIN 350Z S-Tech | 3000K HID Fogs | Hardwired Beltronics Pro RX65 | Batmobile G35HL1 Overlays | Last edited by chilibowl; 07-27-2007 at 03:42 PM. |
| Tags |
| 6mt, correctly, drive, g35, g35driver, mt, rpm, shift |
| Thread Tools | |
| Display Modes | Rate This Thread |
