MyG37.com | G35Driver.com | My350Z.com | ZDriver.com
Show Your Support Become A Premier Member
Go Back   G35Driver > General Discussion > The G-Spot
User Name
Password
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Register FAQ Members List Calendar Search Today's Posts Mark Forums Read
Thread Tools Rate Thread Display Modes
  #61
Old 07-30-2007, 01:09 AM
i have been driving about 2 months and i have conquered hills and smooth shifts. my question is why is 1st to 2nd never smooth unless i give a little gas when shifting? also is it ok to give a small mount of gas when upshifting
  #62
Old 07-30-2007, 04:41 AM
Send a message via AIM to Klubbheads
^first to second, u are letting the clutch out too late, so u automatically give it some gas to match the revs with second gear. If u get the timing right u shouldn't have to use the gas pedal while shifting. It will not happen overnight. It takes time.
__________________
Quote:
Originally Posted by RPL View Post
Why would sedans have greater drivetrain loss?
Quote:
Originally Posted by bonkrokz View Post
longer driveshaft then coupe and z, i think the z and coupe have c/f driveshafts aswell where sedans do not ..plus overall its a longer distance from the motor to the rearend ..
  #63
Old 07-30-2007, 07:59 AM
Send a message via AIM to chilibowl
Yes, you do have to equalize with some throttle input, and the more gas you add, the faster you have to let up the clutch.
__________________
'06 DG Coupe 6MT | INJEN CAI | 15% Llumar | VLEDS | JDM Clear Corners | TEIN 350Z S-Tech | 3000K HID Fogs | Hardwired Beltronics Pro RX65 | Batmobile G35HL1 Overlays |
  #64
Old 07-30-2007, 02:22 PM
RBull's Avatar
Runners FTW
2008 Infiniti G35
Quote:
Originally Posted by chilibowl
Thanks bro, Is there a way we can get this stickied?
My pleasure.
I'm not a mod so can't help there. Maybe send a pm to your favorite one and ask.
  #65
Old 07-30-2007, 06:42 PM
oh no I wasn't asking you, I was hoping some mod would of came in and read the thread, but it has already happened
__________________
  #66
Old 07-31-2007, 02:42 AM
thanks for the tips. my second question is about power shifting. i just started to try it and its not that bad, i dont grind gears but im not sure how to go from neutral to first from a stop, is it possible and how do i do it? also someone mentioned using power shifting for drag, is this really dangerous or can it help? thanks
  #67
Old 07-31-2007, 10:48 AM
What do you mean going from neutral to first from a stop? lol. Simply press the clutch in, and move your shifter from neutral into 1st. lol
Powershifting is a technique where you dont lift off the gas pedal to shift. In other words, if you dont lift off the gas, and you push the clutch in, the revs spike up very quickly because the throttle is at WOT. Dont try and learn powershifting, because powershifting isnt really necessary, and all youre doing is abusing your transmission. When youre drag racing, launch off, redline 1st but dont wait till you actually HIT the redline, right when it nears about 100-200rpm, you shift into 2nd. You always wanna shift at the last millisecond before it hits the rev limiter/fuel cut. The 05-07 6MT rev-up motors have that higher redline for a reason, to use those last 500 RPMs. When racing, you always want to be in the sweet spot, the powerband. If you shift right at redline, you will be higher in the powerband in the next gear, which will grant you more power and top end.
__________________
  #68
Old 07-31-2007, 09:29 PM
maybe im using the wrong word. not power shift but i am shifting without using the clutch. btw thanks for the info
  #69
Old 08-02-2007, 09:38 AM
G35 - Review
Quote:
Originally Posted by M.I.A. BlazinVQ
wow this is VERY good info as im a Newbie MT driver and im about to get a G coupe 6MT. if u have any more tips on what NOT to do with a MT please feel free to PM me or post on the thread. thanks
I gotta tip..
Save your money and get a car that's not a POS..
G35 6MT's suck *** if you get an 05 and up..
so buy used, or don't buy at all. You'll get more enjoyment out of a pinto, because they don't have to go to service as often..
I'm not a board troll either. I once thought the G35 was a great great car, until I hit 3000 miles and only had 2 cups of oil left in the engine. That's when I realized that the car is crap.
It wasn't until recently that I realized the actual company is worse than any other company you'll ever have to deal with.
You'd think, after my car's been though 30 some odd quarts of oil they'd consider replacing things like the entire exhaust, seeing as how it's COMPLETELY black and clogged with oil, nope.. .. now if my CEL comes on and it's determined the exhaust is causing it then they may do so. .. Or if my car catches on fire because the cats are clogged...
Other reasons they suck.. Well, when my dealer replaced my engine they didn't tighten up the motor mount. I brought it back 4 times.. the 3rd time they told me it was my cold air intake making all the noise.. I didn't agree, but said OK, I'll take that off so you guys can find the real problem next time.
The 4th time he STILL couldn't hear the noise, so I took him for a ride and he finally heard the noise.. Loose motormount.. I've had a loose motormount for 3500 miles.. but... They say it won't cause any damage to any other part of the car because the other two motormounts were ok.. I raise the BS flag as the least it could have done was damage my other two mounts.. the most is sent vibrations through every part of the car that shouldn't be there thus causing other parts to come loose, which will show it's self in about 20,000 miles when my car starts to rattle unmercifully.. They think I'm full of crap because I"m not a mechanic, I'm a customer.
OK, so my car has the following issues.
1 loose sway bar - fixed
1 loose motor mount after they replaced the engine - fixed
1 replaced engine because of the OIL consumption problem (known problem) -fixed
1 headlight just decided to stop working..
and 35 days in service because they make you go back over and over and over before they finally fix the problems.
After filing under the lemon law they denied my claim, even though TN state lemon law specifically says 3 tries at one problem, or 30 days in service in the first year.. I meet both requirements..
I call to find out about this and they said my dealer told them that all my problems are caused by my driving habits.. *** HOLES!!..
I wish I never bought the G35 and I am going to print out about 400 flyers to hand to people pulling into the Infiniti dealer this weekend.. I will explain why they shouldn't buy one..
I think you shouldn't buy one either.
__________________
07- Aprilia RSVR, 03 - Sport trac, 04 Victory Vegas, 67 MGB-GT, 00 Monterey 180 Edge, 06 6MT Kinetix Hi-Flow Cats, Kinetix Plenum, No-Frills CAI Injen SES
  #70
Old 08-02-2007, 01:03 PM
What the f*ck does your rant have to do with driving a 6MT? My car has served me well, and im sorry to hear your problems, but you just got a dud bro. Your car was simply built, on a friday night, nearing New Years ... LOL
__________________
  #71
Old 08-02-2007, 01:34 PM
2003 Infiniti G35
pretty much every thing the OP mentions is pretty accurate, and a lot has to do with "getting in touch" with the car, i found the more i thought about shifting smoother the harder it was, then i started going by feel and sound, and it became instinctual, of course, i started in this:
500lbs, 600cc, 110hp, 12k rpm, 6sp Sequential tranny. probably committed my worst speeding infraction in that, 100kph in a 5kph zone (: (it was on school property and a school project), shame i graduated before making it street legal (:
but yeah, took a lot of work to get it to shift smoothly, so i had lots of practice by the time i got a MT car of my own (91 accord, what a disappointment after the above)
__________________
beigish/silver 2003.5 "oh, it's just a" sedan
  #72
Old 08-02-2007, 05:21 PM
Quote:
Originally Posted by MightyMouse
I gotta tip..
i have already had trans problems and i believe i have the oil problem too. there are also alot of rattles and other things wrong with this car. i do feel your pain but i also enjoy working on cars, the only thing stopping me from selling is the fact that this car has potential. just wanted to share that.
o yea... i was thinking about getting a 240 and using the money to mod the shiz out of it and make a super drift car. but idk
  #73
Old 08-02-2007, 07:54 PM
Yeah, my plan is to get my money back out of this car and buy something used and cheap, so if I do have a problem, its almost expected..
I was thinking about just getting a Hyundai Sonata for driving around and then an 04 MR2 Spyder to turbo charge..
__________________
  #74
Old 08-03-2007, 04:46 PM
Send a message via AIM to digitalhifinet
I gotta tip..
Yes we feel sorry for you, but you claim not to be a board troll, yet I just read this exact same post in your other thread. Please don't crap on the forum just because you are pissed off at Infiniti.
  #75
Old 08-05-2007, 02:31 PM
Good post but a few things I disagree with.
You missed a step in double clutching.
1. clutch in
2. shift to neutral
3. clutch out
4. while clutch is still out, shifter still in neutral, blip throttle/rev match
5. clutch in
6. shift to desired gear
7. clutch out & gas
Double clutching does still have its purposes.
1. It saves synchros.
2. It lets you downshift to first, which is when I double clutch (I also double clutch when dropping 2 gears out of habit)
Another thing about downshifting into first.
Cars with low torque, e.g. 4 cylinder cars, will lug in 2nd gear going at speeds lower than 5-10 mph, especially up an incline.
Help your engine out, downshift to first. Lugging is extremely bad for the engine.
Tags
6mt, correctly, drive, g35, g35driver, mt, rpm, shift
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
G35Driver - Archive - Top
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Copyright ©2002 - 2008, G35DRIVER.COM All Rights Reserved.
Advertising - Terms of Service - Privacy Policy - JOBS
MyG37.com | My350Z.com | ZDriver.com | G35Driver.com
