Mystery Noise: Sounds like a stone hitting under the car
I was driving around today inside a parking garage to see if I could hear the noise from outside the car, no luck. Seems I can only hear it coming from the inside.
Also, Its defiantly not the exhaust cooling off. I drove around for aboout an hour (separate incident) then sat outside in the cold, cold air on Saturday and didn't hear it then either.
-G
__________________
-G
__________________
I drove ttrank's car solo
Received 1,486 Likes
on
When I got it back from Infiniti they made it sound as if there was a loose or rattling body panel. I didn't inquire as to what they did exactly but that particular noise disappeared. It wasn't the rear axle/bearing problem these cars have had. I really can't give any more details because I must have gotten it fixed over a year ago now.
Now I live in a area with very textured roads that make a lot of road noise. However, when I drive around on the concrete highways in the area I don't hear it so I'm satisfied.
Try to listen for it when you are turing hard left or right (at any speed) which could mean a CV-joint is going bad (if AWD).
If it increases with speed and repeats it could be a wheel bearing but that should get worse with speed. Try to turn the wheel left/right by pushing/pulling on the tire. It shouldn't turn at all.
Check the tire tread for a stone. That noise starts to drown out at increasing speeds.
on
TWASkyliner
02-08-2020 08:00 PM
kinetek
08-03-2015 04:25 PM
tehmoonrulz
07-19-2015 10:44 PM
