Thread Tools | Search this Thread | Rate Thread | Display Modes |
Brake/VDC Off/SLIP
Notcied on my car that my brake/ vdc off light & slip light are all on at the same time.
Dealer wants $60 to just check out car, says it could be brakes or bad hub? Anyone know for sure which one it is?
__________________
03 G35 Blue Auto Coupe.
my car did the same thing, do the gas pedal ecu reset and it should go away, mine occured when i turned to sharp and i got a little tire spin
__________________
2006 g35 sedan debadged w/ sport and prem. fujita CAI, MD 5/16", Borla exhaust, 18% tint. |
check the brake fluid and see if it fixes it. mine did the same thing so i put some fluid in it and it went away for a little while. then it came back so i took it to the dealer (under warrenty) and they said i had 10%ish or less of my pads left so after they put in new ones it seems to be fixed.
- i am not expert but thats what mine did |
yea but i just got all new pads and this happened after so idk. Mine is gone and hasnt come back up.
__________________
Quote:
then its not what was up with mine then. prop just the fluid like they said |
Quote:
__________________
Cheryl '07 6MT Sedan, Blue Slate with Graphite interior, Premium, Nav, Splash Guards, SSR GT3's, Tint SOLD: '04.5 5AT Sedan DG/G ROLL TIDE ROLL!! The Bear can finally rest in peace!! |
Quote:
+1 My 05 Pathfinder is doing the same thing. I called Nissan because it still has the power train warranty, and Nissan wanted $95 for a diagnostic. They said if the part is under warranty, there's no charge, but if they found the problem and it wasn't under warranty, the fee would apply. They also said if I had it fixed there, the $95 would go towards the bill to fix it. Took it to my father (a mechanic) and the scan came up the front wheel sensor (ABS). The parts on order ($59.17 for the part), and should be in tomorrow. In the meantime, about 25% of the time my wife goes to hit the brakes, the ABS kicks in. A little scary for her.
__________________
03 Sedan 5AT B.O./Willow ~ Pics & Info (Click)
One day your life will flash before your eyes. Make sure its worth watching. |
i was getting all three lights cuz i have 225/35/19 in front and 245/40/19 in rear and vdc was getting different speeds from front tires then from rears.
took it to dealer and tech explain this to me. had to buy new front tires FTL. |
Quote:
__________________
Mine did this and it was a throttle body sensor or something like that, it was under warranty so i didnt ask too many questions. not much help sorry
__________________
-60mph roll?, Everything is even at zero!- |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Display Modes | Rate This Thread |
