Thread Tools | Search this Thread | Rate Thread | Display Modes |
I'm missing these screws
I guess I could go by a junk yard and find them but does anyone know where I can find them online? They are from the rear bumper and Aero rear valance. I looked at Lowes but they don't have any like that. I also need that rubber washer. Does anyone have them that took their stock rear bumper off for an aftermarket one?
__________________
2004 DG G35 Sedan 6MT - OEM Nismo Aero | 40% Hüper Optik ceramic tint | Centerforce DF clutch | UR Flywheel | Idle pulley delete Last edited by Andrei : 08-24-2008 at 04:13 AM. |
Quote:
I'll be mailing those to an online store so I can get the exact same ones.
__________________
2004 DG G35 Sedan 6MT - OEM Nismo Aero | 40% Hüper Optik ceramic tint | Centerforce DF clutch | UR Flywheel | Idle pulley delete |
Quote:
![]() Still need them.
__________________
I'm surprised that your dealer wouldn't have them. Those screws are all over the car. I mean, the dealer HAS to have those in case of repair. At the very least, if you get desperate, you can probably have a body shop order them for you.
Went and bought some screw drivers and found some rubber type washers in the casing they were in
__________________
You could just buy some regular sheet metal screws and use some thin washers, or even reaplce the screws with nuts and bolts for a little more permanent hold. I'm not sure exactly what the application is, but I'm sure some variation from the OE wouldn't be too bad.
Are those screws the same as this screw?
__________________
2004.5 DG 5AT Coupe with all options | GroundingGear | Completely invisible hitch |
Quote:
Today I went by a body shop the local Infiniti dealer uses. They said they don't sell parts there only do body work ![]()
__________________
Check out www.everythingg35.com or call them at 1-888-216-5328 if you can't find the screws on the site. Might as well order some more stuff at the same time to make the shipping worth it.
Heath
__________________
2005 Infinti G35 A/T Sedan 30K, 1990 Infiniti Q45 87K, 1997 Nissan XE Truck 130K |
Ordered some of what I thought were the right screws from infiniti-parts.com
I just picked 4 of each from around the bumper and fender. This is what came in. The small black screws at the bottom I need. The silver ones I don't need. And the clips at the top left I need. I wish the silver screws were the black ones since I need more black ones There is another version of the black screws which are bigger that are around my rear bumper and rear Nismo valace that are not suppose to be used so I'll need to order the plastic fittings that the small screws go into to make it right ![]() I just ordered 12 more of the lil ones and the grommets they go into ![]()
__________________
2004 DG G35 Sedan 6MT - OEM Nismo Aero | 40% Hüper Optik ceramic tint | Centerforce DF clutch | UR Flywheel | Idle pulley delete Last edited by Andrei : 09-27-2008 at 07:40 AM. |
Quote:
NM. They are $2.21 now
__________________
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Display Modes | Rate This Thread |
