Service Engine Soon, VDC Off, Slip lights are all on
#136
What part is it that you bought? My g35 is acting up takes a few seconds to start up, once I hit 60mph it does like a lil light jump and then the vdc off light aswell with the slip light turns on. Once I stop , turn off try turning back on it'll take a few seconds to turn on. I'll turn it off let it sit , then turn it back on and it turns on regular. Vdc , and slip light is off but engine light is on. But once u hit 60mph it'll do it again . Some times it'll just stall out of no where. It says camshaft sensor on the diagnostic, but I read and say it doesn't work. I see last post was awhile back so it might be fixed already? I need as much as info I am pregnant and wanna be safe while I'm driving
Good luck!
#137
g35
This sounds like a camshaft sensor issue to me. Mine ended up being several bent pins on the wiring harness from the dealership and another shop (due to all the prodding and testing) which weren't making good contact anymore with the ECU pins. Finally had a high end Jaguar shop fix it for another $2200, took the other shop to small claims and won, and traded the G35 in after about 6k more miles. I'm driving a 2011 G37S now. I do not think your issue would have anything to do with the harness or pins, and would recommend taking it to a reputable shop to have it fixed. I'm leaning towards one of the camshaft or crank sensors in your scenario.
Good luck!
Good luck!
#139
I apologize for the lengthy response time. I'm currently out of the country. But I had to replace the cam shaft position sensor. It was an fairly easy fix. You can purchase the part from your local auto store, if you know someone to do the work it can be done in 30 mins. I had never worked on a car and used this site https://g35driver.com/forums/g35-cou...y-version.html and YouTube to get the job done. Post back how it went for you and congratulations on your pregnancy
#141
Just replaced both sensors bank1 & 2 , while at it I removed throttle body and clean it, only problem I ran in was trying to remove the sensor from the green connector, after an hour of trying I finally just cut few zip tie that hold the wire harness and use channel lock pliers to release sensor from connector... bought sensors from infiniti dealer on Amazon much cheaper than dealer here in WA...didn't want to go cheap route with non OEM product...
#142
g35
now my car engine light is on, and when I turn it on it goes good then it jumps like a lil sometimes . Sometimes it doesnt. But when I stop and let go of the brake it stays kind of still moves a LIL bit I'll have to hold gas in a lil harder like im forcing it. When I stop turn it off and turn it back on the engine lights still on and the "at check" light beats on n off like 4 times then turns off but the engine light is still on. Ok I put it on drive and it's regular I drive good then again wat I'm typing is happening all again :/ smh ..help
Wayne9011
07-27-2015 11:25 AM
