MyG37.com | G35Driver.com | My350Z.com | ZDriver.com
Show Your Support Become A Premier Member
Go Back   G35Driver > General Discussion > The G-Spot
User Name
Password
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Register FAQ Members List Calendar Search Today's Posts Mark Forums Read
Thread Tools Rate Thread Display Modes
Old 08-06-2009, 05:33 PM
engines
My only concern with "built" engines is.....I have read some people spend big $$$$ from big name shops and the engines being torn down and not "built" properly and not taking responsibility when the motor blows in a few months....I want my motor to last a few years.....
With a G37 block it is strong from the factory. So if we can use g35 heads on the G37 block I have a strong OEM motor that might actually last more than a few months.....The G37 motor can handle more boost from what I read? Stronger rods? Might be worth the swap if I could get a short block cheap enough and the G35 heads bolt on to it???
what do you guys think? hope that clarifies my thought on this.....
Old 08-06-2009, 05:39 PM
if your going to spend that much money on a 3.7 mine as well go with the titan engine
Old 08-06-2009, 08:06 PM
Xet Xet is offline
ya def not worth it. or put in a ls1 or ls6 or ls1000000000. from every topic like this i have read, every time it has been concluded to cost way more than the price of having a quality built motor.
__________________
05 DG 6mt coupe | 5-6% tints all around
Old 08-07-2009, 09:35 AM
twin001's Avatar
2006 Infiniti G35
Send a message via Yahoo to twin001
I think you may be referring to a story about a guy who bought a built block, had it shipped to him, then had another guy install it and install the FI. Engine blew and fingers started pointing.
If you have the money then build the engine. The G37 has stronger rods, but if you are simply swapping out rods then do a complete build. Yes, it would be cool to have the 3.7, but it isn't economically feasible at this time.....especially compared to a built motor.
__________________
2006 DG 6MT Coupe | Nav | RAS | PowerLab | Motordyne MREV & XYZ | Hotchkis | UTR | K&N | OSIRIS | Falken | NISMO | Akebono BBK (see my DIY on the install) | Stoptech
Old 08-09-2009, 10:27 PM
what is your goal here? if you're looking to build a vq35, why not build a 3.7?
the 3.5 can take a beating.
Old 08-10-2009, 02:26 AM
MJ-G35's Avatar
Death before Dishonor
Send a message via Yahoo to MJ-G35
OP if your really thinking bout getting a a truly hardcore built VQ35 talk to Greg @ Injected Performance. Their doing really big things with the VQ, look at injectedperformance.com. Just my .02
__________________
A 3.5 Liter Infiniti.
Old 08-10-2009, 03:17 AM
donpisto's Avatar
Double Trouble JagerStyle
Send a message via AIM to donpisto
You can also look into GTM (http://gtmotorsports.com/). They're known for boost and built engines.
__________________
Team OutCast Gs - Human Resources Director
Obsession, Chivalry, Gallantry
WWW.TEAMOUTCAST.NET
Old 08-10-2009, 02:39 PM
Just buy a 37
__________________
05' G35 coupe/Premium/Sports Package
Old 08-13-2009, 12:05 AM
i would love the G37 motor in a first gen G35. would it fit easily? the 330 horese it comes with stock, the awesome sound and a 3300lbs car vs a 3700lbs car. that would be nice!
stick to stick to make things easier.
Old 08-13-2009, 11:45 PM
The ammount of $ to make it all happen, you might as well invest in a nice turbo kit
Old 08-13-2009, 11:58 PM
Quote:
my way yields better gas mileage!
Old 10-26-2009, 04:41 PM
2006 Infiniti G35
how much would it cost to make this swap happen? just a rough estimate anyone?
Old 10-26-2009, 05:19 PM
Law to the Rence's Avatar
Lawww Dawwggg
2005 Infiniti G35
just give it a few years and we'll be seeing some more realistic VQ37 swaps
so far, i haven't seen any
it seemed unreal to swap a VQ35 into any other car back in '03 but look at the situation now...as time goes by, they become cheaper & more available and you see more and more 240SX's, 240Z's, even Sentra's with VQ35 swaps
__________________
~ Cheers from Law
クルマのよろこびを。 日産です。
Old 10-26-2009, 05:40 PM
EncoreCestMoi's Avatar
what exactly makes the swap so cost prohibitive?
If you were able to find a complete undamaged salvage engine with harness and ecu what more would be required?
I would think it is essentially the same block with the same mount points and I can't see nissan changing the trans bolt pattern.
Buying a complete new crate engine from nissan would be a different story...
__________________
06 6MT V2 OB coupe, nav, RAS, Kinetix SSV, FI exhaust, 350Z S-techs, 20mm spacers, slotted/drilled
  #30
Old 10-27-2009, 02:37 PM
GrocryGettr's Avatar
We get this kind of request all the time and what we tell customers is to ask themselves, "What is my horsepower goal?" If that is the question, the VQ35 has been taken to 1000hp.
If the question is "I want something unique that makes my hp goal?" then be preparered to spend some money.
__________________
WWW.CINMOTORSPORTS.COM -
Tags
2007, block, cost, crashed, detailing, engine, g35, g37, heads, infiniti, long, motor, problem, sale, salvage, swap
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
G35Driver - Archive - Top
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Copyright ©2002 - 2008, G35DRIVER.COM All Rights Reserved.
Advertising - Terms of Service - Privacy Policy - JOBS
MyG37.com | My350Z.com | ZDriver.com | G35Driver.com
