| New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login |
Thread Tools | Rate Thread | Display Modes |
painting my headlights blk gone wrong.. Help!!!
ok so i took out my headlights baked and painted them all came out really nice. i put my lights back it connected everything right. i turned the lights on and all the interor lights went out, turned the headlights off and all of my interor light went on... i thought it was a ground, nope it was the dimmer, then i fixed that issue and now i realized my side marker lights wornt work.. mabey its the fuse? i cant find that fuse someone plzz help!!
__________________
03 DG coupe, 6mt, navi, hks hi power, spa 5000 turbo, terbonetics kit, greedy bov... |
there is a fuse for the side markers, taillights, and interior lights behind the battery. you must remove the battery to get to it. I think it's the top left fuse
__________________
05 BS Coupe - Sevas | Tein | Invidia | Stillen | Crawford | Unichip | JL | Escort |
i just loked in the diy section and saw that and checked it but no luck.
__________________
Did you replace any of your bulbs with LEDs? LEDs have polarity and will short the circuit if you connect them the wrong way. The fuse will be blown if that is the case. The fuse block for it will be below the battery so you have to remove the batt to get to it. Good luck!
Indeed, if you have LEDs in your corners pop them out and try the stock bulbs(after changing the fuse) and see if it still has the problem.
__________________
Motordyne/ Magnaflow/ Berks/ Tein/ Kakumei/ Razo/ NiftyShifty/ Rays/ Muteki/[KuXxxxxx/ |
i have stock bulbs, i checked the fuse box behind the battery i looked at the top left fuse and it was good so idk where else to look. i didnt know there was a fuse box under the battery?
__________________
they are no fuses under the battery.
The fuse box is right behind the battery and you shouldnt have to remove the battery at all. Check all the fuses and make sure they are all good. |
You will have to remove the battery cor and the stripping/cover under the windshield.
Hope you removed the headlight ballast before baking. If not, might of literally cooked it and why stuff shorting out and popping fuses now.
G/L
__________________
06 DG 6mt|Aero|RAS|Mods|Revup VQ replacement. |
Wtf
I removed the ballasts and he bulbs, I connected everything Ruhr I doubblw checked, it's just the side markers, it has to be a fuse I just can't find it, I looked at the ones behind the battery, I can't find it
__________________
r u drunk sir
Maybe a dumb question, but are the bulbs blown?
haa sry i was typin from my iphone and in a rush, but no the bulbs are good, i tried replacing them but the new ones didnt light eather, dose ne one know where i can find that fuse? ive looked at the ones listed but no luck?
__________________
sorry for jacking the thread but... does the license plate lights have a fuse for it.. mine arent working and ive already replaced the bulbs..
__________________
2004 DG 6spd mt coupe. ACT heavy duty pressure plate and disc. ACT streelite flywheel. |
did you check every fuse to see if one was blown? Might be necessary in this case. shouldn't take too long to pull all the 10 and 15 fuses
__________________
| Tags |
| 2003, battery, box, changing, fuse, futher, g35, good, headlight, headlights, infiniti, left, location, on, painting, sedan |
| Thread Tools | |
| Display Modes | Rate This Thread |
