MyG37.com | G35Driver.com | My350Z.com | ZDriver.com
Show Your Support Become A Premier Member
Go Back   G35Driver > General Discussion > The G-Spot
User Name
Password
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Register FAQ Members List Calendar Search Today's Posts Mark Forums Read
Thread Tools Rate Thread Display Modes
Old 11-06-2009, 07:28 PM
OCG35's Avatar
Is that the new G39?
2004 Infiniti G35
*the vast majority of ppl will not notice performance difference between 1/2 and 5/16
*1/2" is a little throatier than 5/16"
*gains are a sum of all breather mods, so to say x is better than y has too many variables
*you can fit an engine cover with 1/2" if you invert (flip over) the grommets (and according to some even with normal configuration)
*if you care enough about performance that the tiny difference between 1/2" and 5/16" is an issue - then why are you running an engine cover anyway? It just traps heat and makes about as much difference in performance by running no cover.
__________________
Link to "My Garage" for info about the car
Old 11-06-2009, 08:25 PM
Send a message via AIM to nghiars
Quote:
Originally Posted by SkylineGTR2789 View Post
isnt the difference between the two like 1 or 2 hp...how will you feel the difference between that.
the hp gained is on a different part of the power curve... with the 5/16 you'll have more power between ~2500 and ~4k rpm than the 1/2. the half well have more hp after ~4K compared to the 5/16.
Do you want the power from ~2500-4K or after 4k? Do you want it earlier in your gears or later?
I hope i was able to explain it so you could understand.
__________________
Old 11-06-2009, 09:50 PM
SkylineGTR2789's Avatar
2005 Infiniti G35
Send a message via AIM to SkylineGTR2789
^Understood!
__________________
|.National G Club.||.o5 G35 Coupe.||.Clear Corners.||.Ztube/K&N Filter.||.MD SPACER.||.LED.|
Old 11-06-2009, 09:51 PM
2005 Infiniti G35
Quote:
Originally Posted by CreativeDesignZ View Post
^ QFT, i think its more or less the power curve, but even still the differences are probably unnoticeable
it took me a while to think of what "QTF" could mean..I came up with "Quit fxcking talking" and "question for thought" lol
__________________
Old 11-06-2009, 09:52 PM
Thanks I hardly go over 4k guess i'll stick with 5/16
Old 11-06-2009, 09:59 PM
2005 Infiniti G35
i should have gotten the 1/2 ... whats the point of adding more power if you dont ever plan on using it..
if your at a track and trying to get a good time..when do your RPM's ever fall before 4k ???
seems like the only time 5/16 will come in handy is from a dig and after you shift again you'll be beyond 4k RPM, correct?
__________________
Old 11-06-2009, 10:21 PM
OCG35's Avatar
2004 Infiniti G35
it's QFT not QTF
you forgot about "queef from twa_"
It actually means "quote for truth"
__________________
Old 11-06-2009, 10:45 PM
2005 Infiniti G35
^LOL @ queef
but i would never have guessed the actual meaning
__________________
Old 11-06-2009, 10:49 PM
silencer_0's Avatar
Slowly Learning....
We do use the power, just earlier than we would with a 1/2" spacer, lol.
You're right about the track, but then again, how often are you at the track compared to just daily driving? Again, it just depends on your driving habits, if you're always in the high RPM's, then the 1/2" spacer is more suitable for you. I on the other hand, am usually in the low-mid RPM's, until I feel like having some fun on an empty freeway every now and then .
In the end, you can't go wrong with either spacer.
__________________
'07 OB Coupe | MD Gamma TDX Catback | MD 5/16 Iso-thermal Spacer | F.I. HFC's | F&F Type 2 Coilovers | SPC Camber Kits | FuRookie Intake | SxExCx GK | Osiris Tune |
Old 11-06-2009, 10:56 PM
2005 Infiniti G35
well yea thats what i meant..if you want to have some fun..want fun is there to be had below 4k rpm lol
__________________
Old 11-06-2009, 11:15 PM
OCG35's Avatar
2004 Infiniti G35
you guys act like the 5/16" has gobs of low end trq and the 1/2" has none... the difference between the two is almost null... its not enough for most (probably anyone) to even notice.
seriously, get either one - I promise if you didn't know which one was on there you wouldn't know the difference.
__________________
Old 11-06-2009, 11:50 PM
silencer_0's Avatar
Slowly Learning....
^ Haha yeah I know, I was just making that point for the sake of argument . I guess it's comparable to switching different intakes, minimal difference in performance, just different/louder sound.
__________________
Old 11-07-2009, 09:20 AM
2005 Infiniti G35
maybe the combination of different intakes would make a bigger difference with the plenum spacer installed...
__________________
Old 11-07-2009, 03:46 PM
spinna001's Avatar
i think you are right about that
__________________
06 G35c SS,clear corner JDM, MD1/2 spacer Z-tube with K&N,drop,06 revup velocity stack,hr y-pipe
  #30
Old 11-08-2009, 09:47 PM
i know this is a little off topic but since we're on the topic of hp gains, what is a MREV2 and how does it work/help your car?
Tags
12, cover, engine, g35, motordyne, spacer
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
G35Driver - Archive - Top
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Copyright ©2002 - 2008, G35DRIVER.COM All Rights Reserved.
Advertising - Terms of Service - Privacy Policy - JOBS
MyG37.com | My350Z.com | ZDriver.com | G35Driver.com
