MyG37.com | G35Driver.com | My350Z.com | ZDriver.com
Show Your Support Become A Premier Member
Go Back   G35Driver > General Discussion > The G-Spot
User Name
Password
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Register FAQ Members List Calendar Search Today's Posts Mark Forums Read
Thread Tools Rate Thread Display Modes
Old 11-07-2009, 12:34 AM
Tire Noise: Coupe vs. Sedan?
Hi, I used to have a 2003 Sedan and now I have a 2003 coupe. When I bought the coupe I still had the sedan and thought the sedan's tires were MUCH quieter than the coupe's tires....so I switched them around. To my surprise, the noise level stayed the same...the coupe was still much louder. So I figured that maybe I had a bad wheel bearing. Upon inspecting the wheel bearings, they all seem FLAWLESS. ZERO wiggle, ZERO scraping noises when turning them, nothing!
So my question is...is the sedan's interior simply quieter than the coupe's?
__________________
2003 G35 DP Coupe 5AT
Old 11-07-2009, 12:24 PM
2003 Infiniti G35
You probably have the imfamous front tire feathering issue that afflicts many 03-04 Zs, 03-04 coupes, and many lowered 03-04 sedans. The only real ways to address this is to cross-rotate the front tires every 2K miles, set the front toe to max toe-in (0.16"), and stick with non-directional tires. Unfortunately, these are just ways to slow the feathering issue down. It will always be there.
__________________
03 OB Sedan 5AT, autox-er and drag racer See my garage for all my mods
Old 11-07-2009, 04:45 PM
pfarmer's Avatar
Hard to say, a lot depends on the roads encountered. I had a 95 Jeep and my kid got real sick and we had to go to Seattle. The Jeep had a running issue that showed up as soon as I climbed in so we hijacked a Cad from my brother in law. What was odd was how quiet the Cad was on the roads leading to the freeway compared to the Jeep, but how noisy it was on the freeway compared to the Jeep. I figured much of this was pavement related to the different types of tires as well as ground clearance.
I find my 2008 XS somewhat the same as the Cad, quieter on some roads, noisier on others than my other car which is a 300M with aftermarket wheels and tires (19" Toyos).
__________________
Eagles may soar but weasels don't get caught in jet engines
Old 11-07-2009, 05:49 PM
Quote:
I guess maybe alignment is maybe the problem? Because both cars have the same suspension and they were both running the exact same tires ( I rotated the tires between the two cars ). Maybe I'll check that out.
__________________
Tags
g35, noise, tire
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
G35Driver - Archive - Top
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Copyright ©2002 - 2008, G35DRIVER.COM All Rights Reserved.
Advertising - Terms of Service - Privacy Policy - JOBS
MyG37.com | My350Z.com | ZDriver.com | G35Driver.com
