G35 & G37, Coupes & Sedans
G37 loaner how do you open the gas tank.
Old 01-29-2010, 03:11 PM
jdmeg21's Avatar
I have a loaner while my motor is getting replaced. I've tried unlocking all the doors and push on the gas door open. I couldn't find a button by the steering column for the gas door. and I don't have the owners manual. SO could someone help me with this. the car is on empty and I don't want to get stuck.
Old 01-29-2010, 03:12 PM
I ride G's Avatar
if the door is unlocked, just press the right side of the gas door in and it will open.
Old 01-29-2010, 04:57 PM
slim17265's Avatar
I do not know if the sequence varies but on my 03, you must unlock the drivers side door and with it open turn the key in the door lock twice to the right. then go to the window switches and lift the one towards the glass once. then go to the filler door and push the back side in *(towards the rear bumper)
Old 01-29-2010, 05:00 PM
GeeGirl82's Avatar
Wow, that sounds like a mathematical equation. lol
Old 01-29-2010, 05:01 PM
thescreensavers's Avatar
Mr.202?
Dont forget to fill up on headlight fluid.
Old 01-29-2010, 05:23 PM
blackmamba's Avatar
i actually had a similar problem with a loaner i was given a couple of weeks ago, turns out the gas tank door was broken and i had to bang on the right bottom corner to pop it open
Old 01-29-2010, 05:25 PM
jdmeg21's Avatar
Some people r just dicks I asked a simple question and get ahole answers. I tried pushing on the gas door like my coupe but it wouldn't open I unlocked all the doors and everything
Old 01-29-2010, 05:27 PM
ntrinsik's Avatar
I remember having the same problem.. unfortunately, I can't remember how it opened.
Old 01-29-2010, 05:53 PM
Dan0myte's Avatar
I rented a G37 sedan a couple of months ago. I had to hold the key fob in my hand near the gas door. Having it within proximity of the gas door allowed it to open.
Yeah... I found it weird too. I tried everything! The guys at the gas station must have thought I was insane.
Old 01-29-2010, 06:05 PM
I ride G's Avatar
i have a g37 sedan...all i do is push it and it opens for me. the key is inside the car
Old 01-29-2010, 06:18 PM
GR6RR's Avatar
stick the key between the gas door jam area,, pry that SOB open, its only a loaner.. it shouldnt damage the paint.. its probs just a little stuck on stupid..
Old 01-29-2010, 07:45 PM
dave's Avatar
Try pushing on both sides of the door. The coupe and sedan (on the G35s) open different ways.
Old 01-29-2010, 07:47 PM
B L U E S L A T E's Avatar
Honda Accord
Push the right side of the door. NOT LEFT SIDE. Sedan and coupe doors works differently.
Make sure you unlock the doors. Yes, all the doors. You can do this by pressing unlock button inside the car or use the key fob button twice.
Old 01-29-2010, 10:09 PM
jdmeg21's Avatar
I figured it out thanks guys. I don't get why they would make them different on the coupe and sedan.
Old 01-30-2010, 03:35 AM
mikek46's Avatar
The fuel door, at least on the 06, is locked/unlocked when using the power door lock to lock/unlock the driver's door. After disconnecting the battery, you're out of luck? It stays whatever it was at the time the battery is disconnected. So if it's locked and the battery is dead....good luck trying to fill up
Quick Reply: G37 loaner how do you open the gas tank.
