| New! Use your Facebook to securely log into this site, click logo to login |
Thread Tools | Rate Thread | Display Modes |
http://www.amazon.com/dp/B000Y9YGX4/ref=asc_df_B000Y9YGX41120578?smid=AF8EGQ3KRZQB6&ta g=pgmp-816-11-20&linkCode=asn&creative=380341&creativeASIN=B000Y 9YGX4
^ I just purchased this floor jack from Costco for about $100. I did some research and this seems like a quality jack with a pretty good price. It is rather heavy weighing in @ close to 100 lbs. but is supposed to be a very sturdy piece which should last me a long time according to online reviews. Anyway, the model is ARCAN XL-35R low profile floor jack. I have an 08 sedan dropped pretty low on H&R's right now and wanted to hear if anyone else has had any experience with this floor jack. I just wanted to make sure that it would fit under a lowered vehicle (my car is currently in the shop so I can't check). If you anyone has used this floor jack, please leave me some feedback. Thanks in advance! -Jason
__________________
2008 G35 Stillen / Ark / Berk / Nismo / GTspec / H&R / Eibach / Rays / Vredestein / SxExCx / Wincos |
You need a jack with the roller in front that measures no more than 3.5" in height. Sears, Harbor freight sell them, the one shown is too tall for a lowered G35 unless you carry rollups in your trunk like I do.
Gary
__________________
G35C "Twilight Blue" Volk SF Winnings/Michelin PS2/Stillen Sways/SPC Endlinks/Strut Bar/Tein H-Techs/Bilsteins/Nismo Diff Cooler/Fjuita Intake/MD 1/2" Spacer ISO/Polished Plenum+PS-RAD Tanks/HKS HP Exhaust/Gordee/Gialla Grille/KurumaZ Bumper/Impul Sides/Projectors/JDM Tails & Clears/Tint/AMSOIL |
Gary, not quite sure yet if it will work w/ my lowered sedan. I can't really check right now since the G in the shop. I am hoping that 3.5" clearance should be enough to clear the front but if not, I will have to make some 2x4 mini ramps.
__________________
I am still unsure if I wanna keep the jack or not. Costco has hassle free return policy, so I just picked it up even though I wasn't sure about it.
__________________
I personally just use a regular jack, I just drive up on some wooden blocks than it fits under without the hassle of pulling out the scissors jack. Also a regular jack is way cheaper.. up to you though.
__________________
05 DG 6mt coupe |
That's not low pro jack.
__________________
Do not believe in anything simply because it is spoken and rumored by many. |
Well I guess it would be a low profile jack if you're not lowered
__________________
heres one that a couple of guys here in the forums uses
http://www.harborfreight.com/rapid-p...ack-92782.html light too
__________________
*Team Outcast*// Stoptech brakes and ARC for Sale |
you can get 20% off coupons from car magazines
__________________
I might return this and look into this HF one.. that looks like a much higher quality floor jack. Thanks!
__________________
Quote:
theres also a 3000lbs one.
__________________
I have that same jack from costco as well. Fits great under lowered cars. Use 2x4 blocks of wood if you need additional clearance. That jack does have a minimum clearance of 3.5" with the rollers all the way to the rear of the jack where it steps up. The entire jack fits under the front of my car if I use 2x4's. BTW I'm lowered and running a top secret front bumper.
__________________
Ivory Pearl 2005 G35 Coupe 6MT - Kenstyle Rear, Top Secret Front, JWT Pop Charger w/ Z Tube, Apexi WS2 Exhaust, 5/16 MD Plenum Spacer, 20" XXR 006 Wheels, Stillen Sways, 20% tint, Nismo Shift Knob, Black OEM Grill, JDM Clearcorners + LEDs, LED City Lights |
Quote:
Jason, i have this same jack. If you're planning on jacking from the front, it will fit underneath, if you're on OEM height. None of the HF and Sears jacks will (believe me, my Arcan is the 6th or 7th jack after having to return all the others). None of the jacks i've tried will fit if you're lowered, without using a ramp first. (here's what i used prior to having the Arcan)
If you're lifting from the side rails, even lowered, i'm sure it will fit underneath. Here's my review of it: http://gshack.org/?p=166 - Mike |
That's the key to the Arcan versus the HF one. The HF ramps up to a higher height as it reaches the back, which in turns lodges itself before the ramp plate reaches its destination. (Again, this is if you're lifting from the front).
| Tags |
| 35, 35r, arcan, costco, floor, g35, good, jack, low, price, profile, review, reviews, xl, xl35r |
| Thread Tools | |
| Display Modes | Rate This Thread |
