G35 & G37, Coupes & Sedans
VDC off, Slip on
Old 12-15-2010, 08:48 AM
25smokey's Avatar
VDC off, Slip on
What does it mean when the "VDC off" light is on and the "Slip" light is on?
Old 12-15-2010, 08:55 AM
PAIXAO's Avatar
Could be a number of things, but the first that comes to mind is that your brake pads are getting low. Check your brake fluid and top it off. Your pads will need replacement soon.
Old 12-15-2010, 09:15 AM
darnelled's Avatar
It means you have the "Vehicle Dynamic control" turned off and you're spinning your tires.
Old 12-15-2010, 09:37 AM
_RR_'s Avatar
Your both right.
Assuming nothing is wrong with your car darnelled's post is the obvious and correct answer. However say if your fluid is low, I read those lights will come on during normal braking to warn you.
Old 12-17-2010, 12:44 AM
goodlookin's Avatar
i would assume it's just the brake fluid. i've had the problem before simple fix.
Old 12-17-2010, 11:06 AM
liljohnny's Avatar
When the slip light turns on, is there a throttle cutoff initiated to minimize the slippage? Even with VDC off, the slip light will still come on and in my old car, an 02 Altima, there would be a response from the throttle in it being cut to minimize the slipping condition. How can we get the car to ignore the slipping/spinning tires? Hope you don't consider this a thread jack as it's along the same line of questioning.....
Old 12-17-2010, 11:34 PM
Bri127mx's Avatar
not sure... usually when that happens, or in the times i've seen, was when someone turned vdc off and did a doughnut, the slip light would come on and stay on until you restarted the car...
as before, check the brake fluid and pad wear. if your abs light comes on with the other two, it could mean that you have a wheel sensor out or your tires have too drastic of a difference in size.
Old 12-19-2010, 03:25 PM
Snip3r's Avatar
my car is doing the same thing, but my ebrake light is also on when driving...
my fluids are fine, so I think it's my brake pads.
Old 12-22-2010, 07:59 PM
Hydroshock's Avatar
I had the same issue a couple months ago, they came on a little bit after driving off with the car and wouldn't turn off until I restarted it.
My fluid level was within range but I topped it up to the max line. Also unplugged and replugged the wires nearby the cylinder thinking they're sensors for the brake system (probably fluid level monitor). Haven't had the lights come on since.
05-22-2022 09:26 AM
MThawkins86
10-24-2015 02:07 AM
markbilo
09-30-2015 01:33 AM
vamarris
09-26-2015 12:56 PM
Quick Reply: VDC off, Slip on
