G35 & G37, Coupes & Sedans
Belt Size/Cross Reference help
Old 12-20-2014, 01:59 PM
Coupey's Avatar
Hey everyone. So i have a 2003 g35 sedan and a 2005 g35 coupe both 5at. Im looking to change both acc and ac belts on both cars but am having troubles getting the right part numbers. Im opting to order the gates belts through rock auto. The sedan has a mechanical fan while the coupe has a electronic fan. I went to the dealer and they said both cars use both exact same belts. But when i tried researching myself it was coming up different. If someone can please help me out with gates belt numbers it will be greatly appreciated.
Drive belt for the coupe (Gates# k060465)
AC belt for the coupe (Gates# k040365)
AC belt for sedan (Gates# k040372)
Are these correct?
Old 12-21-2014, 01:43 PM
dsr30's Avatar
The outer circumference of the 372 belt is 37 & 7/8" while the 365 is 37 & 1/8". You should be gtg on either.
Mad A
Not G35 Related
12-08-2015 01:45 PM
reaper76
09-20-2015 11:59 AM
Detailed Image
09-18-2015 03:43 PM
Detailed Image
09-17-2015 07:38 AM
Quick Reply: Belt Size/Cross Reference help
