G35 & G37, Coupes & Sedans
TEMP/HVAC no longer working (radio works)
Old 07-16-2015, 04:55 AM
arora_g35's Avatar
Exclamation TEMP/HVAC no longer working (radio works)
Hi all, I have a 2006 G35 Coupe. A few days ago, all of the temperature controls stopped working. There is no temp displayed by the clock, and the heated seats do not work either. However, the radio still works. At the same time, the gear of the car is stuck in 'park'; the only way to release the gear from park is to use the shift lock key.
Does anybody know the issue or any suggestions? Thanks in advance.
Old 05-17-2020, 11:11 AM
Glen F's Avatar
G35 coupe, no navigation but everything else
I’m having same exact problem as arora g35, not sure how this works but does anybody know the problem
Old 05-17-2020, 01:00 PM
telcoman's Avatar
That previous post was almost five years ago.
The FSM for your vehicle would be a good place to start
https://www.nicoclub.com/service-man...e/2006/atc.pdf
ATC Page 33 has a diagram of the control system.
Many points of possible failure.
Has your vehicle gotten wet lately to cause corrosion anywhere in your wiring harness?
Good luck
Old 05-17-2020, 03:59 PM
Glen F's Avatar
Good luck
thanks for reply telcoman, I’ve looked at wiring and all the obvious things, not sure if this could be the problem with board behind radio like the common problem for climate and radio issues, expensive fix if not the problem
Old 06-24-2020, 01:58 PM
bryanmilio's Avatar
Same issue
You ever figure out what the issue was?
sck2000e
02-03-2018 11:20 AM
Iboostdoyou
04-21-2013 02:31 PM
Swagger_Jacker
08-19-2011 03:00 AM
newyorkg35
09-21-2010 07:36 PM
Quick Reply: TEMP/HVAC no longer working (radio works)
