Tire Rotation?
You can really only do the side-to-side rotation with a directional tire. The tires gets removed from the rim, flipped, and put on the opposite side of the car, it helps with camber wear. I've only done that a few times myself when I wanted to get a few more months out of a set of tires. I'm using Continental tires now that have an "outside/inside" arrangement, so no rotation at all. Just check tire pressure regularly and go.
On the previous owner's receipts, was other maintenance done as well? Sometimes a standard "5k mile package" would include tire rotation along with oil change, fluid checks, etc. but the tires obviously can't be rotated, to the tech would just skip that step.
azslider86
04-20-2016 11:00 PM
