help bouncing idle on 07 g35
Hi
After I cleaned maf sensors and thotle body , the rpm gage and idle up and down continuously between 1100 to 1900 forever .
After the cleaning procedure
I replaced the 2throtle bodys', their thotle sensors and maf sensors with oem ones and
Tried reset procedure sevral times you know releasing "paddle 10 second wait and ......"
But after replacing thotle body
The idle started little lower but
The buning is still there .
There is no code .
Please help me out .
Thanks in advance .
There is no code .
Thanks in advance .
Same issue
Hi
There is no code .
Thanks in advance .
There is no code .
Thanks in advance .
I drove ttrank's car solo
Received 1,486 Likes
on
If you cleaned throttle bodies, MAF, etc, and still didn't fix this, look for vacuum leaks in the plenum where the engine cover screws go in. If the engine cover is off put the screws back in and see if that fixes the issue. If not, look for holes in those weird little attached "chambers" on the intakes - mine rotted out causing some vacuum leaks and weird idle jumps. Look on both the driver's and passenger side intakes.
on
This thread is over two years old.
It is amazing to me that so many post their problems here after spending $$$ and throwing parts at a problem rather than have a dealer hook up the Consult lll diagnostic tool and pay the diagnostic fee.
There are so many electrical sensors and connections thru the wiring harness that are next to impossible to diagnose without the computer software that the Consult tool uses.
Telcoman
Telcoman
Stevoe
11
04-19-2020 03:11 PM
coffeysm
04-17-2016 10:52 PM
JRandallC
04-17-2016 10:12 AM
iTzTeddy
04-13-2016 06:18 PM
