Rear Caliper Slide Bolt - Threads Unfastened, Yet Seized
My rear lower caliper slide bolt is seized. I have removed it past the threads, but the tip it still stuck. It took a lot of force to unscrew the threaded portion it (I'd say around 80 ft*lb to crack it, about 60 ft*lbs to unscrew it).
There are NO threads engaged at this point, yet I can't get it to budge. I've tried hitting it out, as well as adding heat to the bracket, but I'm worried I'm going to damage something.
Does anyone have any suggestions?
BlkG.Sportx03
Tuner & Dyno
19
10-28-2016 09:14 PM
HotRodG35
Engine - Intake/Fuel
05-18-2016 11:07 AM
ninjabong
05-04-2016 05:17 PM
