Windshield washer only works when parked
on
http://www.nicoclub.com/FSM/G35/Seda...5_Sedan/ww.pdf
With the ignition switch in the ON or START position, power is supplied
through ignition relay, located in IPDM E/R
to front wiper relay, located in IPDM E/R,
to front wiper high relay, located in IPDM E/R, and
to CPU located in IPDM E/R,
through 10 A fuse [No.1 located in fuse block (J/B)]
to BCM terminal 38,
through 10 A fuse (No.84 located in IPDM E/R)
through IPDM E/R terminal 44
to front washer pump terminal 2.
Ground is supplied
to BCM terminal 52
through grounds M30 and M66,
to IPDM E/R terminals 38 and 60
through grounds E17 and E43,
to combination switch terminal 12
through grounds M30 and M66.
WASHER OPERATION
When the wiper switch is in front wiper washer position, BCM detect front wiper washer signal by BCM wiper
switch reading function. (Refer to
WW-7, "
COMBINATION SWITCH READING FUNCTION
Combination switch ground is supplied
to front washer pump terminal 1
through combination switch terminal 11
through combination switch terminal 12
With ground is supplied, front washer pump is operated.
When the BCM detects that front washer pump has operated for 0.4 seconds or longer, BCM operates front
wiper motor for low speed.
When the BCM detects washer switch is OFF, low speed operation cycles approximately 2 times and stops.
Telcoman
Blue Dream (07-19-2016)
I drove ttrank's car solo
Received 1,486 Likes
on
Thanks for the link, telcoman, that document is very helpful. I don't really have the ability to troubleshoot the electronics, I was wondering if anyone had had the problem before and knew whether it was usually a problem with the pump or somewhere else in the system. I think I'll try draining the reservoir to see if there was any crud blocking the feed (although since it's a closed system I'm not sure how anything foreign could get in there). Next I could try replacing the pump as it looks like they're not that expensive. If neither of those work I'll probably take it to the dealer. But that document tells me where everything is so I can try DIY first. Thanks again!
Scott
Scott
on
on
What mechanic has access to Consult lll for proper diagnosis?
Better to spend a one hour labor diagnosis charge at the dealer than just start throwing new parts without knowing the root cause failure.
If you just keep replacing parts you might get lucky and eventually replace the correct one with lots of wasted time, money and aggravation.
The perjorative term "stealership" is used by some who think expensive qualified factory training and owning the proper tools should be given away for free.
You get what you pay for in this world.
If you can't afford proper diagnosis perhaps you should have purchased a cheaper vehicle?
Telcoman
Gary
Jnovuse
03-03-2016 11:56 AM
