The 'AWD' symbol...
Snow if I remember right locks power to 50-50, to be only used when driving... in snow.
In addition, the snow button cuts engine power to limit potential wheel spin.
I should add that the ATTESA system is variable. I.E., it functions as AWD from standstill up to about 16 mph. Then it gradually transitions virtually all power to the rear wheels. So the G35x handling at speed is really performing as a rear wheel drive vehicle. But the handling characteristics are not as aggressive as the regular rear wheel drive Gs in recognition of the likely market for the cars: careful, conservative people worried about driving in snow.
The rear sway bar is dinky, which provides conservative drivers easier-to-handle understeer, rather than the more neutral steering of the non-AWD Gs. An adjustable Hotchkis sway bar will cure that "problem."
AmigaJoe (01-16-2017)
I'm not a super expert on the system but I'd say not exactly. Remember the G also has Vehicle Dynamic Control (VDC). My guess is that at 30 mph the AWD system is still sending a percentage of power to the front wheels; how much I don't know, just not locked at 50/50.
If the system senses slippage in traction, it has the capability to throw power to the front wheels if necessary. This is in addition to the VDC system that is sensing slip, yaw, and directional error to assist in straightening out the car through selective wheel braking.
RWD Gs have only VDC. The AWD adds front wheel power capability to the total "correct driver error and road condition deficiencies" equation.
This is my understanding from what I've read here and there in the site and the web. There's actually a Wikipedia entry on the ATTESSA system IIRC. Hopefully some of the real techs on the site can chime in to correct whatever this guy who is playing at answering questions on a forum without portfolio has really mangulated. ????
Here's the link to the Wikipedia entry. The G35x uses the ATTESA E-TS system.
https://en.m.wikipedia.org/wiki/ATTESA
ferrari71298 (01-25-2017)
I really wouldn't worry about the system. It's very advanced. Just make sure you have a quality set of tires on the car, and you will have no problem at all driving in the snow with it.
My G35x was probably one of the best cars I've ever driven in the snow with. I took it out in some deep snow and never got stuck. Total confidence with it.
SNOW mode is to be used when there is snow on the ground only. It's locks the center transfer case at 50/50 much like a part-time 4WD system on a truck. Great for getting moving from a stop. But, since the front and rear wheels are locked, it makes for some tire drag in tight corners, which is why you want to use it in the snow so the tires can slip a little.
Once the roads start to get clear, go back to normal mode.
To be honest, I used to drive in NORMAL mode all the time, even when it was snowing. Allowed me to have some fun, but I still never had issue driving around.
