Fuel pump relay/fuse??? Help!
Last night my car died on the way to a friends house. It basically just sputtered out like it ran out of fuel.
Long story short, my car sits for long periods of time in a garage. The fuel pump stopped working so I went to investigate. To my surprise mice had built a nest up between the fuel tank and the bottom pan of the car, in doing this they chewed through my wiring harness so that some of the wire for the fuel pump plug were bare.
I re-spliced some new wire for the plug, and I manually tested the fuel pump and it does work. I cannot however get the car to supply any power to the plug. I have checked for a fuse or relay which is most likely blown due to the situation, but cannot find one under the hood or in the interior fuse panel.
Can anyone tell me where this fuse or relay might be? Surely it has one???
I have also consulted the owners manual, and googled many different terms with no luck.
Thanks for any help you can give me, I'm getting kind of desperate.
Car crank no start
Car cranks no start. Alarm solid. No fuses no relays blown. I dont hear fuel pump hum and ik it works car doing this since 4 days ago its a 2005 g35x. I will be replacing the ipdm see what thatcdoes because i dont even get communication on scanner i did when it ran.
I break it down what happen 4 days ago wjen i brought car ran flawless next day i brought two headunits off two diffrent people one worked great but wasnt loud enough for me so i switched from dual to double din pioneer no apple pay just regular multicolor changin radio soon as i hook the pioneer up car wasnt runnin when doin all this soon i hook it up and bam something popped so change the radio fuse cause it was blown no other fuses was blown including relays also changed crank sensor. All i know now is car cranks no start alarm light solid wjen cranking no hum from fuel pump Please let me know who got rhe solution thank you
mliu66
09-06-2014 07:25 PM
ross6200
05-06-2007 10:37 PM
