| New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login |
Thread Tools | Rate Thread | Display Modes |
I own a 05 Coupe. My problem is that I have this annoying creak coming
from the suspension on the front end. I have had it to the dealership 3 times they have changed the compression rod bushings and sway bar links but the squeak is still there. It is only evident at slow speeds when going over uneven pavement especially when making a turn. Does anyone have any experience with this ? The dealer ship can't find anything wrong but it is so annoying to me. I don't think it is anything major but I would like to get some peace of mind. Any suggestions or previous experience with this issue ? Thanks Last edited by GMan1; 09-17-2008 at 10:53 AM. |
I think I got the same problem too. and yes it is anoying. I just turn up the volume of my stereo or close the windows.
__________________
Stock: 03 Gcoupe 6mt Brembo pack.
I had that problem awhile ago...in the front end there are rubber boots at the suspension joints. In my case the grease in those boots dried up. Instead of replacing them (which was expensive) my mechanic took a grease gun with a small needle connection and filled all the boots back up with lubricant. Then we sealed up the small holes with some sort of silicone compound (I forget what he called it) and that took my squeaks away. It has been about three years since the fix, and it is still quiet. This may or may not be your problem.
__________________
03 BS G35C 6MT - Team OUTCAST//APS Extreme TT//Cosworth VQ35DE//Corner 3//Treble Racing |
lol i had the same problem..i took my G to the dealership over 5 times and the 5th time was when they fixed my squeaking..well they said they couldnt find the squeaking but when i drove my car home i didnt hear anything haha...so i guess they fixed something..but yea my front end squeaked like a mofo when i went over little bumps or imperfections on the road...my infiniti dealership still doesnt know they fixed my squeaking haha
__________________
Ohio G Club Member **Ninja** ....Nissan Skyline 350GT.... |
i had that problem too, took it to some Auto shop, and htey fixed some bracket under my car, not probs since ( KNOCK ON WOOD)
__________________
03G35cZtube bullsh*t tuna, nobody likes the as*hole here!!!!!
Thanks, all input is appreciated.
well the squeaking in my car has gotten to the point where i need to make a post about it. its driving my f'in insane! its this little squeak that is heard anytime i go over bumps or anything uneven. although the OP said its coming from the suspension, in my case it sounds like somewhere near the seats.
and i thought my subaru was annyoing with the rattles...that's expected compared to being half the price of this car. |
mine does the same someone got a fix?
mine does the same.. It also does it when I get in and out of the car.... so I dont know if you guys had the same problem.
__________________
National G Club -The "Lek Administration" |
GREASE THE CHASSIS!! Start with the sway bushings and go after every moving part that have bushings
My G just started making some sort of squeaking noise last night driving home. I think it has something to do with one of my belts because it is somewhat of a rotating sound.. if that makes any sense. All I know is when I go faster it slowly starts to fade out (like I need an excuse
) Hopefully it doesn't cost much to fix!
Quote:
i think yours is AC belt, i had the problem when i first bought my car, the dealer fixed it bu t remembering it cost them 300 bucks to fix it. |
Quote:
Went to the Nissan dealership yesterday to see if their guys could look at it. By the time I got there the service part was closed.. However, I did get to see the new GTR up close and personal... sexy. |
The sound of the belts going bad is very different that the sound of bearings. When you hear the sound try turning the AC off, if the problem is the AC belt the noise should disappear.
| Thread Tools | |
| Display Modes | Rate This Thread |
