| New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login |
Thread Tools | Rate Thread | Display Modes |
Speaker rattle in right door
Does anyone have a rattle in the door speaker? My right door speaker rattles when I'm on a road that isn't very smooth. When you barely put pressure on the grille, the rattle stops. I have the car at the dealer now for their 2nd attempt at fixing it. It's annoying, especially since it's on the far side of the car and I'm usually in the car alone.
Thanks. |
I don't know about the door. My rear passenger side speaker rattles, so I just adjusted the fader towards the front speakers to +2 and turned the bass down to 4..no more rattling.
My rear right speaker was rattling a bit also. So I removed the the door panel and it turned out the rattle was the little paper cone that sits on top of the speaker. The adhesive holding it onto the speaker had failed a bit and the cone had come loose. On bass tones or heavy guitar riffs I think it caused the cone to rattle against the inside of the door panel. I super glued the thing back down onto the speaker and since then all has been fine.
I just got the car back from the dealer and they replaced the speaker. Had no impact on the rattle. The rattle happens whether the stereo is on or not. And it's only on rough roads. This the 2nd time they have tried to fix the issue.
Mine did that too when the speaker was on and i found out it was actually not the speaker after the dealer changed it out it was where the door edge closest to your leg attaches to the rest of the door by the drink holder by the speaker. it was a little detached and it rattled against the edge when the speaker played. Hope that helped it was my experience.
plastic door insers werent in all the way
__________________
2004 Graphite Coupe!! 6Speed! Couple of Goods, For now...
slight push an pop them in
__________________
mine did the same thing and it just went away one day. ? weird. Good that you got yours fixed
the dealership replaced my entire driver side door plastic cause it had a dent in the speaker ring...my rattles stopped after that.
| Tags |
| back, front, g35, rattle, rattles, sound, speaker |
| Thread Tools | |
| Display Modes | Rate This Thread |
