| New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login |
Thread Tools | Rate Thread | Display Modes |
Problem with my new lug nuts. HELP!!
Okay guys,
Here's the problem, I recently put on my new lug nuts yesterday, Muteki SR48s on Tenzo R Type M. Today I was driving down my block slowly with the windows and the rear would creek/squeek, kinda like a rubbing noise. I go out to check my rear right wheel and the lug nuts were loose. So I tighten them again, had my girlfriend slowly roll down the street and they become loose again.. ![]() Now I can't figure out the reason why it does this.. So any comments guys? I appreciate it.
__________________
what's next?
are you sure u got the right size lug nuts cause i believe Muteki SR48s are 1.5 while our lug nuts are 1.25. might be the problem!
__________________
04Coupe6MT|Pioneer|MotorDyne|Injen|AEM|Espiler|HKS |Volk|JWT|Kenstyle|Polk Audio|Bazooka |
^^^...yes yes thats it
__________________
* TEAM iNTRO *
also had that happen to me after installed extended lugs. Forgot to properly lock em in so a few had ridges srtip and gotten loose so vibration basically loosened the rest and lugs would come undone.. was a hassle.
__________________
National G Club 04 IP/Blk G35c | NAVI |6MT| Premium | Sport Pkg | Brembo | 20' Venom/Polished lip | Stillen | Clear Corners | Ionic | Tein | R1 Rotors | Axxis | TopSpeed Pro1 | Umnitza | Fast intentions HFC & Exhaust| M3 Projector Fog | Crawford | Rogue Grounding | |
I can almost say thats the issue as well.
__________________
http://www.youtube.com/user/TofuProductionCinema <- Watch me, if you'd like. |
u need 1.25 lug nuts...............
im sure i got the 1.25, i checked it, and im sure because i ordered it from evasive and they sent me the first pack with one lug nut that was 1.5 i was pretty pissed. But im sure its 1.25, i checked each one before i put em on. So far the noise went away but i fear for it.. thanks guys ill let you know if anything else happens.
__________________
what's next?
I can say that my problem relates to yours, how did you solve the problem?
__________________
what's next?
those lugs come in 1.5 and 1.25. u wouldnt be able to screw it in smoothly if u got 1.5.
sounds more a stud is loose or u have spacers and its vibrating. i would regun those studs. that is a very common issue with 5-10mm spacers
__________________
I Hella like my kit Our*Garage/MACH III /fftech~ Hikkatadori Aero kits<-- who needs body kits!?!?!Hikkatadori doriluxe (gialla style trunk!!!) |
Yeah, my first set from evasive had one lug that was 1.5 and it didn't go in, I sent the whole thing back for a new one. I don't have any wheel spacers, and how do you regun your studs? my brother actually had the same problem with his TL, and he had to replace his entire studs, he was using project kics r40.. I'm wondering if I do as well..
__________________
what's next?
I blame the studs, if they had been 1.5s they would not have gone on with out some serious forcing.
Find a custom shop or ask some local mechanics who can do the studs for you, they'll point you in the right direction. Where are you located? google might help.
__________________
Motordyne/ Magnaflow/ Berks/ Tein/ Kakumei/ Razo/ NiftyShifty/ Rays/ Muteki/[KuXxxxxx/ |
thanks 4DGS, yeah i didnt even force the 1.5 in. I tried to spin it on, checked what size the lugs were and i didnt even bother. I'm located in Fresno, CA.
__________________
what's next?
Do a search on google for "Fresno axle/stud repair" or something like that, those guys will be able to pull it off.
__________________
if u are up for a drive i can do it for u for free. didnt u want a bumper anyways lol.
what u might wanan try to is re mounting your wheels vibrations might be causing ur lugs to come off.
__________________
| Tags |
| 2004, coupe, extended, g35, infiniti, lug, nuts, studs |
| Thread Tools | |
| Display Modes | Rate This Thread |
