MyG37.com | G35Driver.com | My350Z.com | ZDriver.com
Show Your Support Become A Premier Member
Go Back   G35Driver > General Discussion > G35 Coupe V35 2003 - 07
User Name
Password
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Register FAQ Members List Calendar Search Today's Posts Mark Forums Read
Thread Tools Rate Thread Display Modes
Old 11-01-2009, 09:29 PM
2006 Infiniti G35
After market air filters cost more than OEM air filter?
Hey guys, my air filter is getting a little filthy so I'm getting ready to change it. I've been shopping around online and saw a K&N air filter for $48 at autozone. Then I looked up an OEM G35 air filter that is $30 including shipping. Why is the aftermarket one more expensive? With that said, should I replace it with an aftermarket or get an OEM?
Old 11-01-2009, 09:50 PM
EncoreCestMoi's Avatar
you only have to buy the K&N once. It's not a disposable filter. When it gets dirty you clean and re-oil.
__________________
06 6MT V2 OB coupe, nav, RAS, Kinetix SSV, FI exhaust, 350Z S-techs, 20mm spacers, slotted/drilled
Old 11-02-2009, 12:05 AM
gary c's Avatar
Papa G
2004 Infiniti G35
Quote:
Yes it's $18 more but you'll never have to buy another filter, just the kit that sells for $10 to clean and re-oil. K&N guarantees their filters for 100K miles, not bad for the extra $....
Gary
__________________
'04 G35C "Twilight Blue" Volk SF Winnings/Michelin PS2/Stillen Sways/SPC Endlinks/Richie Strut Bar/Tein H-Techs/Bilsteins/Nismo Diff Cooler/Stillen CAI+Z-Tube/MD 1/2" Spacer ISO/Polished Plenum+PS Tank/HKS Exhaust/Gordee Grounds/KurumaZ Bumper/Impul Sides/JDM Clears/Tint/CFZ Engine Cover/Red Line
Old 11-02-2009, 01:11 AM
2006 Infiniti G35
Are you guys using the K&N air filter as we speak? I'm a little skeptical at the fact that a used air filter, no matter how much you clean it, can be as clean as a brand new one. What is the oil for? Will using an aftermarket air filter void my warranty?
Old 11-02-2009, 01:38 AM
2003 Honda Motorcycle
My Garage
Send a message via AIM to partyman66
I recommend the Amsoil EA Nanofiber filter... it's cheaper than a K&N, filters the air much better, and is reusable. Oiled filters such as K&N can screw up your MAF sensor if you over-oil them or put the filter in before the spray agent has evaporated.
__________________
2004 Infiniti G35 Coupe 6MT Diamond Graphite, Navigation, Aero, Premium, Brembos w/Project Mu B-Force Pads, Splash Guards, Aluminum Pedals, Z-Tube and K&N Air Filter, 3/8" Motordyne Spacer 2001 Toyota Tacoma Stepside SR5 5-Speed 4X4 Bridgestone Dueler AT Revo 275/70/16's, Sliders, Tonneau, Bedliner
Old 11-10-2009, 09:25 PM
Quote:
That's why you read the instructions and go lightly with the oil. I have been using them for about 6 years now and still no problems.
The oil problem happens because people are impatient, after washing the filter you must wait until it is 100% dry before spraying on the oil.
Old 11-10-2009, 09:53 PM
SwivelHips's Avatar
Clean and Green
2003 Infiniti G35
True.
Truer.
__________________
2003 Emerald Mist/Graphite || Z/Coupe springs||Rays 19s||Stillen CAI w/CF tube || Skunk2 plenum spacer || 350z-Middy || Stillen sways || Philips/PIAA 6000K || nismo shiny things|| AMSOIL syn fluids
Old 11-10-2009, 10:17 PM
Quote:
Originally Posted by SwivelHips View Post
True.
Truer.
There is no such thing as truer.
People typically use K&N more for the performance aspect. They flow more air than paper filters or the amsoil nanofiber.
even a dirty K&N will flow more air than a new paper filter and when properly cleaned are as good as the day it came out of the box.
__________________
Old 11-10-2009, 10:20 PM
SwivelHips's Avatar
Clean and Green
2003 Infiniti G35
More truer. (except not)
http://www.performancemotoroil.com/KN_test.html
Another test, they come out basically even.
http://www.bobistheoilguy.com/airfilter/airtest3.htm
Another win for Amsoil:
http://www.cumminsforum.com/forum/3r...il-vs-k-n.html
__________________
Old 11-10-2009, 11:01 PM
All those links point to amsoil oiled foam filters, not the dry nanofiber filter referenced above. Even the amsoil site omits airflow comparison to the k&n and only compares airflow to a paper filter
http://www.amsoil.com/StoreFront/eaa.aspx
__________________
Tags
2007, air, filter, g35, infiniti, intake, oem
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
G35Driver - Archive - Top
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Copyright ©2002 - 2008, G35DRIVER.COM All Rights Reserved.
Advertising - Terms of Service - Privacy Policy - JOBS
MyG37.com | My350Z.com | ZDriver.com | G35Driver.com
