| New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login |
Thread Tools | Rate Thread | Display Modes |
Help: my car is leaking oil
my car has been leeking oil for about two months now. I did an oil change about three weeks to mobil 1 synthetic oil. My car is still leaking oil:/ it usually only leaks oil at cold starts meaning almost every morning. It is leaking oil by the oil pan. I will post a couple of pictures in a bit since I'm on my iPhone. Any ideas why it's leaking? And how much it'll be to repair it?
This is what i found this morning
__________________
There a little rubber/plastic ring, if you supposedly tighten it too much this ring may crack. My car was also leaking oil, and this was apparently the probem. $20 part at the nissan dealer, and fixed it right up.
Should I take it to the Nissan dealer then? Or buy the part and do it myself?
__________________
I took mine to the Nissan dealers, =). However, if you're more fluent in cars then you could do it yourself. But that was just a suggestion from one of my previous experiences, and your car seemed to show same symptoms mine had.
Mine is leaking from the oil pan bolt. I've been lazy lately. Instead of removing the entire underbody plastic cover. I just remove a few bolts and bend the plastic back far enough for me to reach the oil pan and filter.
This doesn't give me enough leverage to fully tighten the bolt. So I do see a few drips near the bolt. Since it's a crush washer, if you don't tighten it right, it becomes loose over time. |
The Oil pan bolt and washer would be most common. It is quite unusual for our cars to leak oil. The most accurate way of finding the culprate is gunking down the bottom area with degreaser and wiping it clean. Then look for it when it first starts leaking. Good luck.
__________________
04 G35 Coupe/5AT/Premium/Ivory/Graphite/Clear Bra |
Did you get a new washer or reuse the old one? I haven't done an oil change myself yet on my g but from what I've read you should get a new crush washer and not reuse the old one.
i reused the washer. do u guys know about how much itll be at a local mechanic shop or at the nissan dealer?
__________________
I suggest go down to autozone and purchase that blue oil leak detector. put in you motor oil, drive around for about 30min, then get under car with a flash light and detect where the blue colored oil comming from. (first wipe everything clean, prior to doing the testing)
__________________
OEM style made clean my way ![]() 4wisemen Glance
the crush washer? I got mine for free but its 0-5 bucks at the infiniti dealer, and less at Nissan dealer.
__________________
SFL G Club 05 OB SedanS |Z-tube|Clear Corners|
no i meant for the service to fix whatever the problem is.
__________________
What it will cost you depends on where the leak is, the crush washer might not cost you anything if they're cool. If it's something like valve cover gaskets it will cost consideralby more. Stay away from Infiniti, take your G to Nissan and the cost will be less regardless of the issue your having!
Gary
__________________
'04 G35C "Twilight Blue" Volk SF Winnings/Michelin PS2/Stillen Sways/SPC Endlinks/Richie Strut Bar/Tein H-Techs/Bilsteins/Nismo Diff Cooler/Stillen CAI+Z-Tube/MD 1/2" Spacer ISO/Polished Plenum+PS Tank/HKS Exhaust/Gordee Grounds/KurumaZ Bumper/Impul Sides/JDM Clears/Tint/CFZ Engine Cover/Red Line |
| Tags |
| cooler, crush, g35, g35driver, leak, oil, part, washer |
| Thread Tools | |
| Display Modes | Rate This Thread |
