My 60K Checkup...What do I need done?
60K Service....?
It should be very close to the 30K mile visit and keep in mind you don't NEED to have INFINITI do the service. You can have Nissan service your G or a reliable independent shop. If you don't have a warranty you could start using synthetic fluids in trans/diff, guaranteed to make everything work better. At 60K I'd have ALL fluids flushed/replaced, replace all filters and drive belt. Check brakes and suspension for worn bushings etc.
Gary
Gary
If you have a 6mt, then NOTHING. Provided you've changed the oil religiously. And yes, they will recommend services you do not need.
The less time they spend with your car, the better. You don't know how many 6mt Z's and G's have gone through dealerships for transmission fluid change and they end up putting differential fluid in the transmission. Don't let anyone touch it unless required
I drove ttrank's car solo
Received 1,486 Likes
on
Oh really???
any how
Arent spark plugs also changed at 60k?
HAHAHA.... I hope they don't take you seriously, I'd only oil mine if they squeeked. Changing spark plugs at 60K is probably something I'd do. I recall changing plugs 3 times on my '92 300XZTT by 125K miles when I sold it.
Gary
on
i'm goign to repeat what gary said
at 60k i'd replace all filters and fluids.
Radiator Fluid
Transmission Fluid
Diff Fluid
Engine Oil
Xenon Fluid
Engine Air Filter
Cabin Air Filter
also check belts and brakes.
i had to change my belts at 45k~ normally they last 60k or so i hear.
Radiator Fluid
Transmission Fluid
Diff Fluid
Engine Oil
Xenon Fluid
Engine Air Filter
Cabin Air Filter
Radiator Fluid
Transmission Fluid
Diff Fluid
Engine Oil
Xenon Fluid
Engine Air Filter
Cabin Air Filter
Radiator Fluid
Transmission Fluid
Diff Fluid
Engine Oil
Xenon Fluid
Engine Air Filter
Cabin Air Filter
Xenon Fluid?
