Burning Oil Solution.....
I am not sure have this idea been mentioned before, but for those who has the oil comsumption issues have you guys ever tried using a thicker oil. Something like 10w-40 or even 20w-50? I would think that the oil comsumption be a little less if the oil was thicker. Just a suggestion.
On older cars with worn piston rings, using a thicker oil will actually help raise the compression a bit. If oil is being burnt due to the piston rings, I think this would help.
Using a thicker oil than needed may decrease the mpg very slightly depending on the clearances. Usually cars with 100k+ should not have any problems with this unless the vescosity is in the extreme compared to manufacturers recommendation.
The problem with OC is poor quality piston rings, thicker oil isn't the solution. I can only imagine how much $ these garbage rings have cost Nissan, and yet they have never come forward and stated exactly what the issue was or where they were manufactured....to my knowledge.
Gary
Gary
Gary
Pretty damn stupid.
Gary C is 100% correct. The oild burning problem is especially prominent in the high rev engines with manual transmissions. I have an 06 g35 and my block was replaced at the dealership at 46000 miles for free because it was under infinity warranty which is 4 years. What happens is when you have bad or worn out piston rings, the oil gets into your combustion chamber and burns off. One of the reasons he piston rings are there is so the oil does not get in the combustion chamber and your intake system.
