Issue with window reset - G35Driver
Show Your Support Become A Premier Member
Thread Tools Search this Thread Rate Thread
Old 04-14-2011, 06:04 PM
xxkylexx's Avatar
hey guys,
I just installed a new driver side window motor and am at the point where I have to do the reset. I have followed the instructions I found on the infinitihelp site (with door open roll all the way up, close door, hold reset button and roll window all the way down, release reset, roll window all the way back up, open door), however, it doesn't seem to be working.
when I open the door the window rolls down a bit (more than normal though), and when I close the door, the window does not go back up on its own. each time you open the door, it keeps going down a little bit further, and never goes back up any when closing the door back. to get it to go back up all the way you have to roll it all the way back down and then back up. the auto-up feature is also not working. however, the auto-down does work.
again, I have tried doing the reset several times, and it doesn't seem to change anything. any ideas?
Old 04-14-2011, 06:55 PM
xxkylexx's Avatar
Something interesting I just noticed. The instructions I was following on infinitihelp say:
Project: Power Window Reset Procedure
Models: 2003-2005 G35 Coupe
http://www.infinitihelp.com/diy/gcou..._procedure.htm
Is the procedure different for a 2006 coupe (what I have)?
Old 04-14-2011, 07:01 PM
I would think that yours being a 2006 might be a problem. Call a shop like Z1 motorsports or something.
Old 04-15-2011, 02:30 AM
xxkylexx's Avatar
I took the reset button apart. It seems like the button just puts pressure on a sliding plate to stop it from rotating when the window goes up and down. I held it in place manually with a screw driver to stop the plate from moving, which appears to be what the button is suppose to do, however, I am still getting the same results.
Any ideas? Is this motor bad? Any other way to do a reset?
Old 04-15-2011, 10:08 AM
I'm having the same problem!! My door has the original motor though and this issue just started happening a few weeks ago. It's exactly how you described it to a T. I have an '03 though and I guess I'm gonna take the door apart this weekend and do the reset
Old 04-15-2011, 03:16 PM
xxkylexx's Avatar
I replaced the front piece (where the reset button is) of the new motor with the one from the old motor and reinstalled. Seems to be working now. New front piece must have been defective. I just hope that the old front piece isn't part of what was failing on the old motor.
Old 04-24-2013, 06:13 PM
Quote:
I have the same probleme as you with 06 coupe! I want to know how did you replaced the reset button from your old one to the brand new? Thx for helping!
Old 04-25-2013, 07:09 AM
Blue Dream's Avatar
I drove ttrank's car solo
xxkylexx
Send Message User Lists Edit User Profile
Last Activity: 04-13-2012 02:21 PM
He hasn't been on the forum in over a year so maybe someone else will help you out.
Old 10-12-2013, 05:01 PM
Victeur G, did you ever resolve this issue? I'm having the same problem now.
Thread Thread Starter Forum Replies Last Post
Transgo Shift Reprogramming Kit Adventure madmax032 Drivetrain 8 01-18-2016 11:41 AM
2005 G35 Coupe - Window Problem - Weird leo38cheng G35 Coupe V35 2003 - 07 7 11-12-2015 07:49 PM
Stereo system malfuntion. Need help! Phalanx V36 Audio, Video & Electronics 0 08-10-2015 12:31 PM
Silver G35 coupe suggestions? Kal Hamm G35 Coupe V35 2003 - 07 2 07-24-2015 09:55 AM
Power Window Problems. apintojr G35 Sedan V35 2003-06 0 07-23-2015 11:52 AM
Tags
2003, 2006, 35, auto, automatic, back, button, g35, infiniti, power, reinitialize, reset, rolls, sedan, window, windows
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Copyright 2002 - 2008, G35DRIVER.COM All Rights Reserved.
