Possible Vacuum Leak ?
Old 04-29-2011, 01:56 PM
cmesidewayz's Avatar
After installing a new air filter, z tube, MREV2, and 5/16 iso thermal spacer, and grounding kit i noticied some weird idling ! I reset the ECU and did the throttle learning procedures..
So on a cold start before the mods it would idle at about 1800, now it idles at 1600 and goes down faster than normal. and jumps once in that process from 1400 to 1600, happens every time...
Idle with AC it stays at 800, from a normal distance away from the gauges it doesnt seem to move but if you get up real close it appears to go up and down a very very slight amount... same for with the AC off, except at 600... It only happens about half the time Is this normal ?
Do i have a small vacuum leak ? or is the computer still learning ? its been allmost a week since the mods were done..
any help is much appreciated
besides that i love the midrange power
Old 04-29-2011, 03:10 PM
sillyoldtayo's Avatar
If you had a vacuum leak I would think you would have a constant idle issue. Double check all your hoses and make sure they are connected, also make sure the rubber neck of the oil fill area isnt stuck in between the upper and lower plenum.
Old 04-30-2011, 12:40 AM
coupetech's Avatar
did you torque down the intake manifold in proper sequence? the intake mani can easily get cocked (giggity) if not properly tightened. also did you need longer bolts to accomodate for the spacer? Check for vacuum leaks by running the car and spraying carb/brake cleaner around the manifold, gaskets, vac lines, etc..idle speed will increase if there is a leak
Old 04-30-2011, 07:47 AM
Yeah I checked everything, haven't tried using carb cleaner yet... I will get some when I have the chance
And it seems the gauge is completely constant with the AC on almost all the time now and with it off it's going up and down in a non rhythmic way maybe 75rpms at most
Something I forgot to mention is that I used the inner part of the stock gasket.. Other than that I followed motordynes directions by the word with torque sequences etc.
I used a ft pounds torque wrench instead of inch, I convertedthe numbers, but maybe the torqueing wasn't accurate ?
Old 04-18-2019, 11:16 PM
Jbutku4's Avatar
I think that's a normal noise, mine sounds like that too once I swapped hoses, I believe that the OEM one is more insulated.
Old 04-19-2019, 03:08 PM
Pbfoot's Avatar
04 G35 Sedan performance package. 70k Eibach springs and sway bars. 19 inch wheels. Plenum spacer.
You realize this thread is 8 years old?
KruZZe
02-27-2023 05:04 PM
RemmyZero
V36 DIY
04-23-2018 11:13 AM
KallDay86
01-08-2016 12:42 AM
hrdwirk1
10-02-2015 06:34 PM
vamarris
09-26-2015 12:56 PM
Quick Reply: Possible Vacuum Leak ?
