Show Your Support Become A Premier Member
Activity Stream: Show All | New Threads | New Posts | New Pictures | Popular Threads | Lonely Threads | Only Vendor Threads | New Picture Comments | New Profile Comments |
Go Back   G35Driver > General Discussion > G35 Coupe V35 2003 - 07
Sign in using an external account
Register Forgot Password?
Search
Welcome to G35Driver
submit to reddit
Thread Tools Search this Thread Rate Thread Display Modes
Old 06-28-2011, 10:30 PM
Points: 8,901, Level: 63
Points: 8,901, Level: 63 Points: 8,901, Level: 63 Points: 8,901, Level: 63
Level up: 51%, 149 Points needed
Level up: 51% Level up: 51% Level up: 51%
Activity: 0%
Activity: 0% Activity: 0% Activity: 0%
2005 Infiniti G35
Burning smell and smoke coming from engine
Recently my car has had a bad burning smell and smoke coming from my car. The car drives like normal and there are no lights coming from the dash. Any ideas of what this could be? I'm confident that my car isn't consuming oil either. What could be the culprit? Please help guys! My vehicle is a 2005 G35 Coupe 5AT (VQ35DE Non Rev-Up)
__________________
05' G35 Coupe/10' Honda CR-V
Old 06-28-2011, 10:44 PM
Points: 2,718, Level: 31
Points: 2,718, Level: 31 Points: 2,718, Level: 31 Points: 2,718, Level: 31
Level up: 79%, 32 Points needed
Level up: 79% Level up: 79% Level up: 79%
Activity: 0%
Garage is empty, add now
Quote:
Although this may seem obvious, did you check your oil Dip stick? When I got my oil changed, the shop didn't put my dip stick all the way back in which caused some oil to come up and it was making a light smoking/burning smell. Are dip sticks are hard as f*** to get it all the way. Atleast for me it is lol. Goodluck!
Old 06-28-2011, 10:47 PM
Points: 7,469, Level: 57
Points: 7,469, Level: 57 Points: 7,469, Level: 57 Points: 7,469, Level: 57
Level up: 60%, 81 Points needed
Level up: 60% Level up: 60% Level up: 60%
Activity: 29.8%
Activity: 29.8% Activity: 29.8% Activity: 29.8%
2004 Infiniti G35
^ yep.. look for oil splashes
__________________
don't mind me, I really don't know what I'm talkin about.
Old 06-28-2011, 11:46 PM
Activity: 0%
2005 Infiniti G35
I'll look for this tomorrow, thanks guys.
__________________
Old 06-29-2011, 12:14 AM
Trickstyle's Avatar
Points: 3,082, Level: 34
Points: 3,082, Level: 34 Points: 3,082, Level: 34 Points: 3,082, Level: 34
Level up: 22%, 118 Points needed
Level up: 22% Level up: 22% Level up: 22%
Activity: 0%
2003 Infiniti G35
My Garage
Bukakke_For_You Steezy777
thnx! I was having the same issue, dip stick fix worked :P
Old 06-29-2011, 10:30 AM
Points: 2,921, Level: 33
Points: 2,921, Level: 33 Points: 2,921, Level: 33 Points: 2,921, Level: 33
Level up: 14%, 129 Points needed
Level up: 14% Level up: 14% Level up: 14%
Activity: 6.5%
Activity: 6.5% Activity: 6.5% Activity: 6.5%
facbook.com/midcity3608 thesource26
I had this problem in my maxima and it turn out to be my valve cover gasket.
Old 06-29-2011, 08:25 PM
Points: 1,643, Level: 23
Points: 1,643, Level: 23 Points: 1,643, Level: 23 Points: 1,643, Level: 23
Level up: 44%, 57 Points needed
Level up: 44% Level up: 44% Level up: 44%
Activity: 0.3%
Activity: 0.3% Activity: 0.3% Activity: 0.3%
had the same prob in my car. still having it once in a while.
Old 06-29-2011, 08:28 PM
RollingG's Avatar
Points: 372, Level: 7
Points: 372, Level: 7 Points: 372, Level: 7 Points: 372, Level: 7
Level up: 44%, 28 Points needed
Activity: 1.6%
Activity: 1.6% Activity: 1.6% Activity: 1.6%
best thing is to check your oil Dip stick and go from there.
Old 06-29-2011, 10:29 PM
Points: 2,716, Level: 31
Points: 2,716, Level: 31 Points: 2,716, Level: 31 Points: 2,716, Level: 31
Level up: 78%, 34 Points needed
Level up: 78% Level up: 78% Level up: 78%
Activity: 0%
2005 Infiniti G35
Same thing happened to me......oil dipstick.
Old 06-30-2011, 03:50 AM
Points: 3,391, Level: 36
Points: 3,391, Level: 36 Points: 3,391, Level: 36 Points: 3,391, Level: 36
Level up: 28%, 109 Points needed
Level up: 28% Level up: 28% Level up: 28%
Activity: 0%
2005 Infiniti G35
yea i dont like the location of the dipstick..
__________________
2005 G35 Black MT Coupe / 1999 Infiniti Qx4 Black
Old 06-30-2011, 11:57 AM
Activity: 0%
2005 Infiniti G35
I checked the oil dipstick and made sure it was in tight. I saw that it was very dirty around the oil dipstick and drove around and the problem went away. However it came back again after I drove the car a second time. How much would it be to cost the valve cover gasket?
__________________
Old 06-30-2011, 12:16 PM
Points: 5,696, Level: 48
Points: 5,696, Level: 48 Points: 5,696, Level: 48 Points: 5,696, Level: 48
Level up: 73%, 54 Points needed
Level up: 73% Level up: 73% Level up: 73%
Activity: 3.5%
Activity: 3.5% Activity: 3.5% Activity: 3.5%
2003 Infiniti G35
http://www.facebook.com/W.Ulitsky WUlitsky HockeyPlaya91RU
Send a message via AIM to G35SedanGrn Send a message via Skype™ to G35SedanGrn
If you are under warranty faulty valve covers are common & ur dealership won't even argue replacing them, they leak oil and it pools around the spark plugs, I had this same issue & the valve cover was the reason.
__________________
2013 Galaxy Blue Silica Subaru BRZ Limited 6MT
SOLD -> 2003.5 Sedan Emerald Mist
Old 06-30-2011, 02:18 PM
Activity: 0%
2005 Infiniti G35
I wish I was under warranty, I'll give them a call to see how much it would be to fix. Is it a difficult job to do?
__________________
Old 06-30-2011, 02:29 PM
Activity: 6.5%
I'm not sure how much a valve gasket job will cost because me and my friend changed mines out we did all the labor on it.
One way to find out if it is the V gasket is to take that plastic cover thing that sits ontop the motor get a flash light,drive around the block a few times (when it's dark outside)until you notice the smoke.once you see the smoke immediately pull over,open the hood and flash the light around the valve cover area.do all this while the car is still running.
Old 06-30-2011, 02:48 PM
Activity: 0%
2005 Infiniti G35
Thanks I'll give that a try, it sounds like I have to change all the spark plugs too.
__________________
submit to reddit
Tags
2003, 2005, back, burning, burnt, car, coming, engine, g35, infiniti, it, light, smell, smoke, smoking
Search this Thread:
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2
Copyright ©2002 - 2008, G35DRIVER.COM All Rights Reserved.
Advertising - Terms of Service - Privacy Policy - JOBS
G35Driver.com | My350Z.com | MyG37.com | ZDriver.com |
Everyone's Contact Details
