help,,car wont start! :/ 2005 G35 coupe
I second what he says. You most likely don't have a good strong, solid connection on the battery terminals. Take both off, clean the terminals and connectors, and put them back, making sure to get them good and tight and all the way down on the battery posts.
It all happened after i finished installing my spark plugs and put back the battery cables...also fyi, number 6 sparkplug was filled half ways with old oil, i cleaned out all oil and coil and put new sparkplugs in..i might need new engine gaskets.
No solenoid click when i crank it.
positive terminal
negative terminal
Its hard to tell from your video but i heard a click that sounded like your solenoid. nevertheless check all your fuses with a meter or test light. If you don't know how have someone show you how. Pay attention to the ones under the hood.
If that doesnt explain it, you said you had a lot of oil in some of your spark plug tubes. Its possible when you removed a plug all that oil drained into a cylinder which was near the top of its compression stroke. If there was enough to fill the remaining volume of the chamber then as soon as you put the plug back in you sealed that oil in the cylinder. Now the motor can't turn because its basically hydrolocked since that oil wont compress. Remove all your spark plugs and disconnect the coils and try to crank the motor over. If it cranks over that oil will shoot out of the cylinder and clear it out.
well you checked the battery and it runs from a push start, checked ALL the fuses and you are sure they are good, you are sure there is no oil in a cylinder, and assuming your are remembering to push the clutch in all the way (don't laugh, I have seen people forget and then complain their car wont start lol), there are only a few things left to look at that will keep it from cranking and they all require more intense troubleshooting.
1. bad starter or solenoid
2. bad clutch switch
3. bad ignition switch
4. problem with the cars security system, ie. keys, control module, etc.
#30
