Brakes lock up until turn vdc off - G35Driver
Show Your Support Become A Premier Member
Thread Tools Search this Thread Rate Thread
Old 04-24-2012, 09:59 PM
New G owner. Finally. I have searched the forums and couldn't find someone with this problem. When you first start the car and turn out of a parking spot the car applies the brakes i think and it locks up. It will keep doing this until the vdc and slip lights come on. If you turn off the vdc and drive straight until the slip light comes on it doesn't do it just makes a noise. You can still feel it slightly in the pedal. I was told it might be the ball joints, or maybe the hub assembly. Any ideas?
Old 04-24-2012, 10:28 PM
Mine does the same thing bro. From what I understand check out the steering angle sensors (or something like that). I've been dealing with it till I get an alignment and new rear tires. I've only read one other thread that sort of relates to our issue and it pointed toward the steering angle sensors.
Old 04-24-2012, 10:47 PM
^^ yep, probably the steering angle sensor, which needs to be reset/re-learned at the dealership. I had my steering rack replaced (incorrectly, as I found out), and this was the only way to fix the issue. Even getting a fully alignment (at the time the rack was replaced) didn't help - since the car thinks the steering wheel is turned but knows (via accelerometers) the car is traveling straight. This makes the VDC system thinks the car is slipping/skidding.
Old 04-24-2012, 11:37 PM
preciate it fellas. I'll take it tomorrow and see what they say. I'll keep you posted.
Old 05-03-2012, 11:52 AM
Found out what the problem was. The steering angle sensor was bad so got that replaced. Also the cone spacer where the control arm is bolted on was bad. Everything is good now. Finally can move to the performance mods. :-)
Old 05-03-2012, 02:08 PM
Quote:
How much did it cost you to fix it?
Old 05-03-2012, 07:56 PM
^ +1. Would also like to know cause eventually once I fix my thousand other issues I'm going to need this done lol
Old 05-03-2012, 11:13 PM
Where is the steering angle sensor and how do u check if its bad?
Old 05-03-2012, 11:17 PM
My abs trips out when i go over big bumps and in tight turns when i push it a bit.
Thread Thread Starter Forum Replies Last Post
New to FX. Having issues. SiMpLyMoDiFiEd The FX-Spot 1 08-09-2015 08:22 PM
Weird issue 2003 G35 MsFitFern G35 Coupe V35 2003 - 07 2 08-09-2015 03:58 PM
Squeaking when turning right. ddietz97 G35 Coupe V35 2003 - 07 1 07-26-2015 07:16 PM
(Slip light VDC light Off) keeps coming on Mry General Tech Questions 1 07-21-2015 03:03 PM
Decisions, decisions... mushu G35 Sedan V35 2003-06 17 07-15-2015 04:55 PM
Tags
03, angle, applied, brake, brakes, coupe, feel, g35, locked, locking, rear, sensor, steering, turn, turning, vdc
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Copyright 2002 - 2008, G35DRIVER.COM All Rights Reserved.
