(Please Help) U1001 and U1212 error codes
Hey guys I have a project car i am working on it is a 2003 G35 I am building a KIt. The person that had it before me really stripped the car down.
The car starts but i am getting error codes U1001 and U 1212.
My question is was does the Communication Line/CAN look for. What does the connectors look like as well and where are the grounds for this Communication line. I have searched high and low for these answers. I see a ground behind instrument cluster and another ground above ECU on passenger side. Is there something I am missing.
My head lights, tail lights, windshield wiper does not work. the hazards work and the reverse light.
I found this part on Ebay I dont know if I need this or not. I looked in the car and I did not see this part no where.
here are some pics below of car I am building.
The P1212 is a tcs system code. Most likely there is a communication line open going to abs/vdc control unit or something. The part in your pic is a GPS antenna that goes behind the cluster right at the base of windshield(under the dash). This would have been for a car with factory navigation as well. You need to check the U1001 code first since it is relating to the P1212 code. Hope this helps.
RemmyZero
V36 DIY
04-23-2018 11:13 AM
joel extreme
SOCAL Meetings & Events
09-29-2015 04:44 AM
