Low RPM During Idle After 5/16 Spacer Install
Old 01-18-2015, 12:20 AM
G35Tdot's Avatar
After installing my 5/16 motordyne spacer l the RPM seem to be lower during idle. There are no audible leaks and all the hoses are very snug. The car does seems to be more responsive when driving but the idle is so low that you can't even hear hardly hear the car.
A/C was off but turned on it would go up by just a bit and the motor was warm. I do not remember it being this low before I installed the spacer since it was much much louder
Low RPM During Idle After 5/16 Spacer Install-cyetu81.jpg
Old 01-18-2015, 12:24 AM
Lartytiejdke3's Avatar
Your pic isn't working..at least on the app
Old 01-18-2015, 12:25 AM
G35Tdot's Avatar
Thanks! just put up a new link
Old 01-18-2015, 12:54 AM
ScraggleRock's Avatar
You can try the idle relearn, but that's about where mine is too (600-650rpm). Did you touch the butterfly on the TB when you installed it?
Edit: I now see yours looks like about 550..? That is a bit low. I'd try to do the idle relearn and then give it 200 miles to relearn everything.
Old 01-18-2015, 01:07 AM
JHereth22's Avatar
Can we do an election and get Jersey and Scarggle to become admins?
Old 01-18-2015, 01:20 AM
G35Tdot's Avatar
I now just remember as I was trying to put the intake back on I did slip and hit the outside of the throttle body a couple of times. Other than that I didn't touch it. Yea, I think I'm going to give it a week or so to see if it improves then I'll restart the ecu
Old 01-18-2015, 01:21 AM
G35Tdot's Avatar
I agree! They've are really helpful and they reply so fast its like they never leave this site
Old 01-18-2015, 01:33 AM
JHereth22's Avatar
Haha I bet they both are single
Old 01-18-2015, 02:03 AM
I wish. Hahaha jk
Old 01-18-2015, 03:26 AM
JHereth22's Avatar
Well I only hope she can put up with car talk. My gf doesn't even know that you should change your oil. Thank god she's hot
Old 01-18-2015, 03:47 AM
rsingerG35's Avatar
Did you check all of your vacuum hoses? Also did you disconnect the negative battery cable during this install?
Old 01-18-2015, 03:54 AM
izzueeek's Avatar
+1 on the throttle relearn
Old 01-18-2015, 07:48 AM
G35Tdot's Avatar
Haha mine buys me car parts/tools
Old 01-18-2015, 08:01 AM
G35Tdot's Avatar
Yup checked them all, they were all snug. Yea removing the negative cable was the first thing I did. Wasn't too happy about my radio presets being reset but it was worth it. Idle when engine is cold seems normal though going to wait a bit then do a throttle relearn
Old 01-18-2015, 08:41 AM
were actually a couple
Quick Reply: Low RPM During Idle After 5/16 Spacer Install
